2006 6.0 egr (check engine light.) - Ford Truck Enthusiasts Forums
Old 04-04-2010, 04:08 PM
bartman2147 bartman2147 is offline
bartman2147 is starting off with a positive reputation.
put egr bypss kit on my 6.0 everything went well ,the problem now is that I cannot keep my check engine light off , its pulling a code on the egr system. any one know the solution to this problem?
Old 04-04-2010, 04:14 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
I suppose you removed the EGR valve in this process. From what I understand, some 05's and all 06-07's will through a code with the EGR valve disconnected. You will need a tune to turn it off (egr system).
Try this thread for more on it.
http://www.ford-trucks.com/forums/94...-question.html
Old 04-04-2010, 04:22 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Or, Take the old EGR valve, plug it back in but secured to a safe place...
See if that allow you to clear the CEL.
Old 04-04-2010, 04:45 PM
no did not remove egr just bypass.
Old 04-04-2010, 04:47 PM
at first thought it was a bad egr ,so I replaced it with a new one.i have had a couple of guys tell me this is common with 06 and up and they want me to buy a handheld computer that will decode the egr for $350.
Old 04-04-2010, 04:48 PM
You probably need to beg, borrow, or steal a programmer to turn off the EGR ....
It is not just detecting the EGR, but the absence of EGR gas flow... ack.
Old 04-04-2010, 04:49 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Is the code that you are getting an EGR flow code? If so then the only way that I'm aware of to clear it is to get a custom tuner that disables the sensor and that should clear the code. Be the way I run an EGR bypass system as well, although mine was fabricated at the muffler shop, not a commercially bought one.
Old 04-04-2010, 05:51 PM
this is exactly what I was told ,I just thought there would be a simpler way to do it without spending 3 or 4 hundred dollars, on a tuner.thanks for the heads up. I guess my next question is where is the best place to go buy a tuner.?
Old 04-04-2010, 07:26 PM
AutoEngenuity is the one that many on here says is next thing to what the dealer can do....
I wouldn't know because I work off a $50 code reader.
Old 04-04-2010, 08:26 PM
tex25025's Avatar
Quote:
AutoEnginuity won't fix his EGR issue. That has to be done with something that can flash the trucks computer. To my knowledge, it can tweak certain parameters within each of the 9 modules on our truck, but it can't disable the EGR system, except I think for a short amount of time to test things, but once you disconnect the connection it reverts back to whatever the programming on the computer is.
Now for code readings, re-calibrating the speedo and a plethora of other options, AE is the best.
Old 04-04-2010, 08:45 PM
after doing a little reserch youare exactly correct! the autoenginuity is basically nothing but a reader not a delete system for the computer.
Old 04-04-2010, 08:47 PM
tex25025's Avatar
Quote:
Oh no, it's not basically a reader only. Don't think that. It's only for diagnostic purposes. It does more then just read codes, it actuates commands, dataloges, code reads and run tests. However, as far as programming that is where it's somewhat limited and only limited to certain things as well. Not intensive programming like programming the ECM/TCM etc.
EGR Delete's and tuners question. duste 6.0L Power Stroke Diesel 15 10-09-2016 03:06 AM
6.0 EGR delete questions lottery_loser 6.0L Power Stroke Diesel 5 02-26-2014 10:11 AM
disabled egr throws check engine light? jtproudlogger 6.0L Power Stroke Diesel 28 06-01-2012 06:18 PM
EGR Delete...Now Check Gauge light on? Not Check Engine. Jbru167 Excursion - King of SUVs 0 01-24-2011 12:02 PM
Check Engine Light After EGR Delete stokes86 1999 to 2016 Super Duty 7 01-08-2011 04:03 PM
Tags
2006, 60, cel, check, diesel, disable, egr, engine, f250, f350, fine, flow, light, powerstroke, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
