Cruise Control adjustment? - Ford Truck Enthusiasts Forums
Old 04-04-2010, 01:11 PM
teppler's Avatar
teppler teppler is offline
teppler is gaining momentum as a positive member of FTE.
Is there a way to tweek the cruise control on these truck ie when I press resume it takes it a while before the cruise starts to control, on older vehicles you could adjust the vacuum to make response quicker.
Old 04-04-2010, 01:22 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Could be a sticking cruise control disengagement switch.
See link below, near end.
Old 04-04-2010, 03:33 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
CC on a 6.0L is all in the PCM. Meaning the only adjustment would be by programming.
Old 04-04-2010, 04:01 PM
Quote:
Which leaves very few suspects....
Old 04-04-2010, 05:35 PM
teppler's Avatar
Guess I'll learn to live with it, darn this truck has been great, 58,000 miles and replaced the FICM on warranty and repaired a small oil leak under turbo. Life is good right now!! Doing all the recommended upkeep and monitoring temps.
Old 04-04-2010, 06:10 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
yup all in the pcm, it is what it is.
Old 04-04-2010, 07:08 PM
The cost of the cruise control switch is less than $20, and I replaced it in about 45 minutes of work --- and got a bonus brake bleed / fluid change out of it..
Old 04-04-2010, 10:09 PM
IHbase's Avatar
IHbase IHbase is offline
IHbase has a good reputation on FTE.IHbase has a good reputation on FTE.
I have always hated how slow the ford C Control is to respond to input. After I drove the new Dodge with the toggle lever on the right side of the steering wheel (like older BMWs) I really hate my dog-slow set-up. -Mike
Cuise Control bduemig Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 10-11-2013 07:57 PM
Cruise Control njstevens Excursion - King of SUVs 11 02-09-2012 10:38 AM
cruise control mrwrench 1999 - 2003 7.3L Power Stroke Diesel 5 10-19-2009 02:25 PM
Cruise Control sensetivity... DanMartin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 12-21-2003 01:23 AM
cruise control bigblockbronco Bronco II 0 01-19-2003 07:11 PM
Tags
1996, 60, adjust, adjusting, adjustment, adjustments, control, cruise, f150, ford, sct, shift, truck, tuner, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
