snap-on scanner - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
snap-on scanner
Old 04-04-2010, 12:38 AM
kupaa's Avatar
kupaa kupaa is offline
kupaa is gaining momentum as a positive member of FTE.
snap-on scanner
ok i got hold of a scanner for tomorrow what am i checking or which is important.
Old 04-04-2010, 01:39 AM
Layson's Avatar
Layson Layson is offline
Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.Layson has a great reputation on FTE.
I don't know what you can look at on the snap on so I will throw a few things out there.
Injector Control Pressure, HPOP duty cycle, Engine Oil Temp, Injector Pulse Width...
Old 04-04-2010, 01:50 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
The Snap-On with up-to-date software should be virtually the equivalent of a dealer's Ford scanner. Everything should be available if I'm not mistaken.
A buddy who is a quality independent-garage mechanic has one, and that's his claim.
Pop
Old 04-04-2010, 01:22 PM
takotruckin takotruckin is offline
takotruckin has a good reputation on FTE.takotruckin has a good reputation on FTE.
From what I have seen with my Solus, I can get everything the NGS(factory ford) can EXCEPT for turbine shaft speed or input shaft speed for the trans.
Old 04-04-2010, 01:34 PM
kupaa's Avatar
Quote:
I think it's a modis scanner.Do you know how to select which pids to watch or do you have to watch it all?
Old 04-04-2010, 03:11 PM
It depends what update it has in it. If it is before 9.4 you hit N from the pid screen and then there is a menu-select "custom datalist" or something like that.
If it has 9.4 in it from the pid screen go to the furthest right icon, hit Y and then select "custom datalist" and you can pick what pids you want it to show. To graph go to the left view icon and you can select from 1-4 screens.
I will admit the snap on scanners are a little hard to get used to, but once you have it down they are great.
If you get in a bind and need some help shoot me a PM and I'll give you my # to try and walk you through it.
Old 04-04-2010, 05:25 PM
yam02mt's Avatar
yam02mt yam02mt is offline
yam02mt is starting off with a positive reputation.
sorry to ho jack but does anybody know if the Snap on scanner will let you change the speedo for bigger tires?
Old 04-04-2010, 05:39 PM
Not that I have found.
Old 04-04-2010, 08:44 PM
bigsteve1969's Avatar
bigsteve1969 bigsteve1969 is offline
bigsteve1969 has a good reputation on FTE.bigsteve1969 has a good reputation on FTE.bigsteve1969 has a good reputation on FTE.
Pop
a modis wont do as much as the IDS will. snap on has a good code reader for generic stuff but not specific stuff.
Scanner with tuner? ves83 General Diesel Discussion 1 08-26-2014 06:41 PM
Buying a Code Scanner spiggy769 Garage & Workshop 16 09-13-2013 04:12 PM
Best Code Scanner cttbax 1999 - 2003 7.3L Power Stroke Diesel 12 11-21-2012 11:19 AM
2000 7.3l No scanner Communication ant12 1999 - 2003 7.3L Power Stroke Diesel 5 07-24-2008 11:31 AM
Superchip as a scanner oldblue31 1994.5 - 1997 7.3L Power Stroke Diesel 2 11-30-2006 09:50 AM
Tags
codes, powerstroke, scanner, snapon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
