300 pistons
Old 01-26-2003, 11:42 PM
cardude's Avatar
cardude
cardude is offline
300 pistons
Is there any forged pistons made for the 300. how about the rest of the i6s. What are the general valve sizes for the heads. Looking to turbocharge.
Thanks
Old 01-27-2003, 11:18 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
300 pistons
I am planning on using KB-355 Pistons, and 240 rods, to make a long rod 300-6TT. I have to get a 240 rod, and a couple of different pistons to check clearances and whatnot. Go to the KB site ( www.kb-silvolite.com ), and check for pistons with a 4.0" bore, and as close to 1.778" compression height as you can get. My general opinion is that it doesn't matter what brand the parts were intended for, if they are used in a Ford, that makes them Ford parts, right?
Old 01-28-2003, 11:50 AM
Lectrocuted's Avatar
Lectrocuted
Lectrocuted is offline
300 pistons
Hey Jared. Please keep us updated. Very very interested in long rod 300. Good stuff!
Old 01-28-2003, 02:03 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
300 pistons
Not too much going on right now, just research. I have a 300-6 torn down in my father's garage, I need to get it overbored, luckily it was a virgin block to begin with, so it should only need .020" over. I am just porting and polishing the head, and replacing the valves and springs, dual coil springs, but stock valves. SBC valves have very little effect on a turbo'ed motor, and the long rods help it breath better. I am hoping to do a tech writeup on this engine when it is done, and another one on the truck I build for it.
Old 01-29-2003, 07:10 AM
cardude's Avatar
cardude
cardude is offline
300 pistons
what kind of compression ratio will you end up with?
What is the cc of the chambers?
Old 01-29-2003, 01:50 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
300 pistons
I am using a stock 80 head, I think it's 74cc chambers, and with those pistons, if my math is right, it will be 8.0:1. Like I said, I have to get a couple of different ones, and see how they work together. I am also considering having the pistons ceramic coated on the heads, and teflon coated on the sides. Not entirely sure about that, though.
blue924.9
05-10-2013 12:54 AM
timbodee
11-16-2010 08:06 PM
bigdan1979f-250
05-11-2009 05:05 PM
MER
03-06-2008 10:37 PM
RapidRuss
04-17-2007 12:16 AM
Quick Reply: 300 pistons
