what style cam - Ford Truck Enthusiasts Forums
what style cam
Old 04-03-2010, 01:07 PM
IsoGrifo's Avatar
IsoGrifo IsoGrifo is offline
IsoGrifo is starting off with a positive reputation.
what style cam
Just curious as to which cam you guys would use in a F/I 2.3, a hydraulic flat tappet, or hydraulic roller follower?
Old 04-07-2010, 06:22 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Quote:
The roller will not be affected by the low ZDDP levels in the oil. With the flat tappet I would recommend adding ZDDP with each oil change
Old 04-07-2010, 06:25 PM
mud bros's Avatar
mud bros mud bros is offline
mud bros is starting off with a positive reputation.
Quote:
excelent tip!
go with the roller as the open close rates are much faster and allow for more duration without affecting mileage or drivabuility.
i would replace the valve springs with it also to a set from a roller cammed engine
Cam? Fmfl Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 02-08-2015 07:06 AM
68 f100 inline 6 300 build up 68turquoise300I6 Ford Inline Six, 200, 250, 4.9L / 300 1 10-03-2014 12:00 PM
Roller cam vs Flat tappet??? Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 3 10-04-2013 06:29 PM
comp cams 31-255-5 question. need help Nally427 1987 - 1996 F150 & Larger F-Series Trucks 1 11-02-2012 10:01 PM
1995 f150 351 roller cam? green1995 1987 - 1996 F150 & Larger F-Series Trucks 2 01-27-2010 04:33 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
