Converting 302 to roller rockers, what is involved? - Ford Truck Enthusiasts Forums
Old 04-03-2010, 10:12 AM
Nathan Plemons Nathan Plemons is offline
Nathan Plemons is gaining momentum as a positive member of FTE.
I had the valvecovers off of my 302 the other day while I was painting them. I noticed that the lift on the cam must be in the milimeter range, because I really couldn't tell much difference between the open valves and the closed valves.
I figured a fairly cheap way to get a little more out of the engine might be to increase the rocker ratio, but I don't know what the "gotchas" might be.
The engine is a '74 302 that would seem to be stone stock. It was rebuilt many years ago so technically I guess it's a 306. I can't imagine that the springs would be original, but they're probably not really a performance spring either. The rocker studs appear to be pressed in.
I guess my question is, what is the stock rocker ratio (1.6 for ford small blocks?) and what ratio can you go to on a stocker before you start running into valve spring and piston clearance issues? Also, do you need to replace the rocker studs, etc?
I can ramble off the necessary parts on a chevy LT1 in my sleep, but this is obviously a slightly different beast. Thanks!
Old 04-03-2010, 10:35 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Welcome to Ford Land.
Stock ratio on the SBF is 1.6:1 and there are 1.7 and some 1.72 ratio rockers available. If your existing heads use rail style rockers(the tip has skirts to keep them on the valve stem) you either need to replace with this type or add guideplates... which is a bit more involved because of the push in studs of course. This usually means a trip to the machine shop and if that's the case simply substituting a newer head or a set that have already been reworked is the beter way to go. All late model SBF heads(from about 1978 on) use pedistal mount rockers which don't need guideplates and are therefore easier to add rockers too, but in most cases the combustion chambers are larger than the early heads so you could lose some performance. That's not a certainty though it depends what heads you have right now, the casting number would tel the story and that can be found on the head gasket side near one of the intake ports.
Old 04-03-2010, 10:37 AM
Hmm... That's exactly what I was afraid of. In GM world we just call them self aligning rockers. I did not see any on Summit that looked like they would fit my head and be self aligning. Guideplates normally wouldn't be a big deal except for the push in studs as you mentioned. Looks like the truck is just gonna have to stay stock for a while.
Thanks!
Old 04-03-2010, 02:51 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
Comp makes self-aligning roller tip rockers for SBFs, not sure about the ratio though.
Old 04-03-2010, 03:32 PM
Ah, I see them now. Comp makes them in 1.7 but they are only roller tip. My previous search ruled them out because I had specified full roller. They do make a full roller 1.6, they would be mostly pointless. The majority of the HP gain from rockers comes from the higher ratio, not decreased friction. If I get really bored I might try the 1.7 roller tips one day. Better yet I may just hold off and get some good heads.
Old 04-03-2010, 04:35 PM
Roller rockers = ~$200 for maybe 5 hp
Heads = ~$1,000 for at least 50 hp
Definitely save your money for heads.
Old 04-03-2010, 06:03 PM
Well, I've dyno proven 14 RWHP by swapping rockers before. And I've also dyno proven 32 HP by swapping heads, and that was on an engine with a cam / fuel injection system that could take advantage of the swap.
50 HP for heads might be a tad optimistic unless you're planning on putting in a new cam, intake, and headers. Then again, I'm sure the heads I was starting with weren't nearly as bad as what these are, so who knows.
Old 04-03-2010, 10:31 PM
Conanski's Avatar
SBF heads are pretty bad... way more restrictive than any stock SBC casting for example, so heads alone can produce dramatic power increases on these motors if the induction, cam, and exhaust needed to support them are already in place.
351C Vs. 400 rocker ratios Kyle Wood 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-04-2016 02:15 PM
Max lift for stock e7 valve springs 2.5itim 1987 - 1996 F150 & Larger F-Series Trucks 18 09-06-2016 01:53 PM
Late model 5.0 questions about valve train outcrydrummer 1967 - 1972 F-100 & Larger F-Series Trucks 4 01-02-2014 04:46 PM
Rocker Arm Adjustments jtindale Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 07-20-2012 10:45 AM
Update on cheap 1.73 rockers for the EFI engines.. Silver Streak Ford Inline Six, 200, 250, 4.9L / 300 24 01-03-2010 11:42 PM
Tags
17, 1982, 221, 302, arm, cam, ford, rail, ratio, rocker, rockers, roller, run, sbf, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
