calling all super camper specials
#1127
#1128
I'm a little unsure if "styles", we have the trim with the black rubber strip in the middle from the front side light to the rear side light, both sides. we now need the bottom trim front to back. i will be going to local junk yard this weekend, should be able to get some pieces, have seen them but the piece for the spare tire cover might be harder to find
#1129
There is the thinner "Race-Track" trim and the wider Rocker trim, which style, I have both styles for the Spare Cover as I have multiple covers and I won't put trim on my truck.
Will have to check if my parts truck has the other small trim pieces on the passenger side of the bed or if I just have the Spare Cover trim pieces.
Penn79: I also would like to find a set of the Super Camper Special badges, I have many Camper Special ones. Will check if I have that trim piece. Which Vancouver are you in?
#1130
Thanks
#1131
New tire advice
I have a stock 1973 F350 SCS, not lifted. I need new tires. It has 16" aftermarket wheels, which I want to keep. Current tires are 265 75R16. I'd like to go bigger. What is the largest I can go without lifting? Truck is not lifted. I don't mind going bigger on the rears than the front. I actually like this look. I don't want the tires to rub or affect clearance. Thanks for your help.
I just posted this on the main forum, but thought I might get better input here, so it shows up twice.
#1132
For the cab forward F-250 pieces work but not the bed. I need some pieces for the bed. Nice pic BTW.
#1133
#1134
#1136
#1138
#1139
