Power Rating for a NP435 - Ford Truck Enthusiasts Forums
Old 04-02-2010, 09:19 AM
zerfetzen's Avatar
zerfetzen zerfetzen is offline
zerfetzen is starting off with a positive reputation.
Does anybody know how much power you can put through a NP435? How much can it handle?
Old 04-02-2010, 11:02 AM
Drac's Avatar
Drac Drac is offline
Drac is starting off with a positive reputation.
Not yet but maybe by summers end I'll find out if it can handle 400-450hp.
So, i too would like to know.
Old 04-02-2010, 04:12 PM
highboy1975 highboy1975 is offline
highboy1975 is starting off with a positive reputation.
there was a guy on here running over 600hp through his. check out the offroad forum, theres guys running big power to big tires through theirs
Old 04-02-2010, 04:33 PM
RJR99SS RJR99SS is offline
RJR99SS is starting off with a positive reputation.
It's probably one of the beefiest regular automotive transmissions ever made so.....a lot.
Torque would probably be the deciding factor in what breaks it though. I know mine handles 500 ft/lbs fine.
The things that usually break them is people stripping the teeth of the creeper gear though. If you're 4wd and married t-case, i've seen the t-case adapters crack a few times.
Old 05-09-2010, 09:42 AM
gus11208's Avatar
gus11208 gus11208 is offline
gus11208 is starting off with a positive reputation.
my 435 handles 500 hp 600 ft lbs of torgue with no problems
HELP! Need NP435 clutch fork infinite-foamies 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-19-2016 05:23 PM
How much can a np435 take 86fsbronco 1978 - 1996 Big Bronco 6 12-24-2011 02:49 AM
gear shift removal NP435 kingford72 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-19-2011 10:02 PM
NP435 came in.... landon460 Clutch, Transmission, Differential, Axle & Transfer Case 2 01-27-2011 05:43 PM
Rebuilding a Np435 Dustin_86 Clutch, Transmission, Differential, Axle & Transfer Case 2 11-11-2007 05:17 AM
Tags
435, 73, ford, handle, horsepower, hp, np, np435, power, powere, rating, ratins, torque, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
