timing line 4" off
That would be my guess too. The rubber ring gets old and allows the damper ring to move. On an internally balanced engine it's no big deal, all it does is throw the timing marks off. On an external balance engine you will REALLY know when the balancer has slipped, the engine shakes like it's running on three cylinders.
Ok What are you actually asking? That for it to run smooth at idle it is 4 degrees off what you think it should be? If that is what your issue is, maybe check for other issues like your idle speed, vac leaks, bad PCV valve etc.
Are you checking the timing with the vacuum advance disconnected and plugged?
When you connect the vacuum advance are you connecting to a PORTED vacuum source and not FULL manifold vacuum?
If the timing marks line up at TDC, and you're showing the ignition timing as that far off then the distributor is adjusted WAAAAAY out or you are on the wrong cylinder.
Josh
Josh
46fordtruck
2004 - 2008 F150
09-20-2014 02:32 PM
96dangerranger
10-30-2012 08:17 AM
djmac
03-16-2005 02:48 PM
