Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Nebraska Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nebraska Chapter Join Chapter, Leader: 97nukeford
  #1 (permalink)
Old 04-02-2010, 03:24 AM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01 diesel-fitter-bum01 is offline
that guy
1999 Ford F-350
diesel-fitter-bum01 has a good reputation on FTE.diesel-fitter-bum01 has a good reputation on FTE.
Tyler Murphy
Any one pull their truck?
Just wondering. I'm thinking about entering mine in the Pierce co fair or somewhere close(incase I break)this summer. Any pointers you that have pulled desel trucks can give me? Thanks
__________________
Tyler
Owner/operator JBI mobile dyno service.
Mine E99 F-350 sc sb 4x4 updated to L99,307K,FF 250's,arp,uppies,T-500,RR,HPX,4" straightpipe,GTP38R,built trans,airdog,swamps hf/hv,fuel sump,melling lpop,water inj,and DP F6 tunes. lots of little stuff too. 460HP 912 TQ
83 Ranger 2.2 diesel 4 speed 2wd
  #2 (permalink)
Old 04-02-2010, 09:44 AM
fordnut forever's Avatar
fordnut forever fordnut forever is offline
1984 Ford F-250
My Garage
fordnut forever has a great reputation on FTE.fordnut forever has a great reputation on FTE.fordnut forever has a great reputation on FTE.fordnut forever has a great reputation on FTE.fordnut forever has a great reputation on FTE.fordnut forever has a great reputation on FTE.
i cracked up reading your title, yep, i pull mine every time it breaks down,lol,good luck
__________________
RANDY, Its Not Just A Pickup Truck.Its A Ford F-150
{Truck Poor}, Nebraska Chapter Member,"The beauty of the second amendment is that it will not be needed until they try to take it;Thomas Jefferson
  #3 (permalink)
Old 04-02-2010, 11:37 AM
that guy
1999 Ford F-350
Tyler Murphy
Fords don't break down they just need a rest now and again.
__________________
Tyler
  #4 (permalink)
Old 04-02-2010, 12:20 PM
67nukeford's Avatar
67nukeford 67nukeford is offline
Nebraska Chapter LDR
1997 Ford F-150
My Garage
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
There are a few of the guys that do truck pulling in here, I'll see if I can't give them a heads up to stop by Tyler.
__________________
Pat W. Nebraska Chapter Leader and Official #1 Slackmaster/ Avid Winter Hater
2006 F-250 "Black" ARP studs, EGR delete, SCT tuner REBUILD THREAD
1967 F-100 4X4
1967 F-100 Project thread
2013 Explorer XLT (wifeys)
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #5 (permalink)
Old 04-02-2010, 05:07 PM
that guy
1999 Ford F-350
Tyler Murphy
Thanks Pat appreciate it much.
__________________
Tyler
  #6 (permalink)
Old 04-05-2010, 11:55 AM
The Freak's Avatar
The Freak The Freak is offline
Garage is empty, add now
The Freak is starting off with a positive reputation.
Not sure what kind of trucks are running around in your area, and I don't mean to offend the Ford Truck Community, but you are going to have a bitch of a time competing with the Dodges and the Chebbies!! Around here, pretty much any Ford (diesel) that competes usually gets it handed to them. I guess in the 'stock' classes all trucks are pretty much equal, but once you get into the classes where some mods are allowed, the Dodges and Chebbies pretty much end at the top.....However, you don't know until you try it!!! Anything specific you wanted to know??
  #7 (permalink)
Old 04-05-2010, 02:47 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy Redneck-Cowboy is offline
1976 Ford F-250
Redneck-Cowboy is gaining momentum as a positive member of FTE.
In the stock class youll be alright, not sure what the rules are w/ chips at your fair, in Wahoo (Saunders County) they limited everyone to 60HP in the stock class. In anything modified the Fords usually fall short though due to there injection system holding them back in the performance world. After a few years the 6.4 and new 6.7 should be able to run something like a EFI program on a Duramax since they use a common rail setup. The downfall will be tryin to get the emmissions crap that is all over them to accept a program such as that.
__________________
97 F250 4x4, 5spd, 7.3L, Chip, Meth Inj, 5" Exh. 86 F150 4x4, 4spd, modified 300-6. 86 F250 2wd, auto, stock 460. 85 F250 4x4, auto, modified 460/557 (Pulling/Mud Truck). 76 F250 4x4, 4spd, heavily modified 460 (Pulling Truck). 67 F250 2wd, 4spd, stock 352
  #8 (permalink)
Old 04-05-2010, 10:06 PM
that guy
1999 Ford F-350
Tyler Murphy
just any tips on what to do. Never done it before.
__________________
Tyler
  #9 (permalink)
Old 04-06-2010, 07:59 AM
1976 Ford F-250
Well if you can weigh say 8,500lbs and your truck only weighs 8,000lbs (just an example on weight) it would be in your best interest to find 500lbs of weight and get as close to the front of the truck as possiable, so a couple weights on your passenger floor and 3 right behind your seat. Running and automatic/diesel you'll tighten up the sled chain, then you'll want to powerbrake a little to get your boost up (BTW you'll wanna be in 4 low 1st), then turn er loose and hold er to the floor, if it starts to bounce or hop ease out some until it settles down, as soon as your up a decent rpm, prolly 2,700 on a 7.3 shift to 2nd, if it's pulling real easy you might be able to make 3rd for a little bit, but once it starts to pull down be ready to shift down with it. The key is to get as much track speed as you can. You can also just put it in Drive and go to, your tranny just runs higher psi in manual 1 and 2. You may also wanna run your max psi in your rear tires, so at least 50psi if you can, then you'll want to let your front tires down quite a bit, on a gas pickup weighing 6,500lbs, w/ 1,200lbs out front I'm running 18psi in the front tires. When I pulled a stock pickup last I let the front tires down to 20psi, they do squat quite a bit, but with the heavier diesel motor and heavier vehicle in general you'll have to be the judge of how much you let them down to, I'd guess at least 25psi.
__________________
  #10 (permalink)
Old 04-06-2010, 08:27 AM
The Freak's Avatar
Also, depending on what the rules are for the class that you are going to be pulling in, try to get the rear of the truck as 'solid' as possible. The easiest way to do this would be to build some clamps for the rear leaf springs, or if you are motivated and talented enough, you could take a weekend and fab up some removable traction bars for the rear. I'm assuming you will be pulling from your receiver hitch?? Try to keep your hitch height at a happy medium....not too high, but not too low either. Our rules are a max of 26" height. Pretty good height in my eyes so I would shoot for something around there. That height will keep the truck under control and keep the sled from bottoming out too soon. Otherwise X2 on everything that Bouc said!!
  #11 (permalink)
Old 04-06-2010, 10:56 PM
that guy
1999 Ford F-350
Tyler Murphy
Thanks a ton guys very informative info.
__________________
Tyler
Tags
county, fair, pull, pulls, saunders, truck, weigh
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
