1995 7.3 is leaking oil bad please help!!!!!! - Ford Truck Enthusiasts Forums
Old 04-02-2010, 02:16 AM
jasen jasen is offline
jasen is starting off with a positive reputation.
my 95 7.3 is leaking alot of fuel from the top of the motor can anyone help me?????
Old 04-02-2010, 08:46 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/91...-question.html Here is a link to a thread that may help. You will also get better response if you post any questions you have on that Power Stroke page.
Good luck.
Old 04-02-2010, 09:14 AM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
Welcome to FTE jasen. I moved your thread to the 94.5-97 PSD forum. These guys here will take good care of you.
Old 04-02-2010, 09:58 AM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputationDRRXR has a superb reputation
Lightbulb Give some more info
Quote:
Originally Posted by jasen View Post
my 95 7.3 is leaking alot of oil from the top of the motor can anyone help me?????
Is this a liquid oil stream or a slow leak?
Where is the leak exactly?
Turbo area? Engine vally?
etc...
Here is some added info to help you
From the manual
Overview
The High Pressure Oil Control system consists of the high-pressure oil reservoir, highpressure oil pump, injection control pressure regulator, Injection Control Pressure (ICP)sensor, high-pressure hoses, and oil rails in the cylinder heads.
The High Pressure Oil Control system is used to actuate the HEUI fuel injectors. The PCM controls an electronic pressure regulator to regulate oil pressure to the injectors. The high-pressure oil flow within the fuel injectors is controlled by a solenoid located on top of the injectors. Oil pressure supplies the force needed to pressurize the fuel in the
injector to initiate fuel injection. High Pressure Oil Control Subsystem
Description & Operation The lubrication system is comprised of a low-pressure system and a high-pressure system.
The low-pressure system provides primary engine lubrication while the highpressure system provides the hydraulic pressure required to actuate the fuel injectors.
The low-pressure lubricating system draws oil from the engine oil pan through the oil pump screen cover and tube into the oil inlet passage in the front cover. The Gerotor oil pump pumps the oil back out through the outlet passage in the front cover. One oil path sends oil flow to the high-pressure pump reservoir initial fill gallery (integral to the cylinder block) and through the anti-drainback check ball. During cold start the oil feeds in two directions from the anti-drainback check ball. One feed leaves the check ball and enters the front cover. From there it enters the high-pressure oil reservoir. The second feed exits the check ball and enters the left bank valve lifter oil gallery. Pressurized oil that enters the turbocharger assembly lubricates the compressor/turbine shaft. The oil drains back through the turbocharger mounting pedestal and back into the oil pan. The valve lifter oil gallery supplies pressurized oil to the valve tappets and to the piston cooling oil jets. Oil from the valve tappets is routed upward to the cylinder head
valve train through hollow push rods. Oil drains back to the oil pan through return ports. High Pressure Oil System Explanation
During initial start or cold start, the high-pressure oil pump receives unfiltered oil from the left side valve lifter oil gallery through the anti-drain back check ball valve. Once the engine starts or during warm engine starts, the check ball closes and the high-pressure oil pump receives filtered oil from the high-pressure oil pump reservoir.
The high-pressure oil pump pumps the oil under extremely high pressures (4,115-20,577 kPa [600-3,000 psi]) through the left and right side high-pressure supply hoses to the high-pressure oil rails (integral to the cylinder heads). Once in the oil rail, oil is fed to the fuel injector bores through oil feed galleries (4) drilled and machined in the cylinder
head. The high-pressure oil then actuates the fuel injectors.
Old 04-03-2010, 02:43 PM
can anyone help with the 7.3 leaking oil from the top of the motor?
Old 04-03-2010, 03:52 PM
rideracelivemx7's Avatar
rideracelivemx7 rideracelivemx7 is offline
rideracelivemx7 is starting off with a positive reputation.
welcome to FTE but not to sound like a jerk but... dont post the same durn question 2 times with out saying were the leak is specidfically coming from, how fast its leaking when i leaks, pictures would help. theres plenty of spots for this big ol pig to leak and you need to be SPECIFIC lol
a common spot is the back of the turbo pedistal, the orings fail and leak down the back of the block leaving a nice spot in your driveway. another spot is either the pump its self or the lines, which would let oil pool on the top of the motor. give some detail and guarentee we can solve the issue.
Old 04-03-2010, 07:27 PM
foxracing0934's Avatar
foxracing0934 foxracing0934 is offline
foxracing0934 is starting off with a positive reputation.
If it is leaking oil a lot, I'm talking a gallon in 100 miles a lot, then it is most likely the oil galley plugs on the back of the block. There are new plugs from Ford that have a different o-ring on them than the ones that came factory.
Old 04-03-2010, 08:52 PM
scatgo's Avatar
scatgo scatgo is offline
scatgo is gaining momentum as a positive member of FTE.
Quote:
Got a part number for that? I know mine is leaking seems to be worse now that I have synthetic in it.
Old 04-03-2010, 10:01 PM
Desert Rancher's Avatar
Desert Rancher Desert Rancher is offline
Desert Rancher is starting off with a positive reputation.
There are two high pressure oil plugs on the front & rear of each head.
They will start leaking for no apparent reason, it seems to be a rather common problem.
This is the p/n for the new style plug:
4c3z-6026-ca
Have a pic of the plug, but I am unable to post it. Will e-mail it if you want.
Old 04-03-2010, 11:10 PM
scatgo's Avatar
4c3z-6026-ca
Yea sure. Leaking bad now that I am using synthetic so I need to start working on them leaks.
Old 04-04-2010, 08:19 AM
DRRXR's Avatar
Part Pic
Old 04-04-2010, 12:19 PM
scatgo's Avatar
Thanks. Do you know if it is that much of a PITA to switch them out?
Old 04-04-2010, 02:27 PM
DRRXR's Avatar
Nope
I would think that two of them could be a real pita. I have not done mine yet. Scatgo
how about you doing yours and then build a guide on the how to and post for a everyone else to use.
Just kidding, someone on here has had to have done this aready. Perhaps Jim has.
Old 04-04-2010, 02:32 PM
im not leaking oil like i thought i got under there and its fuel alot of fuel and its comin for the to of the motor any ideas?
Old 04-04-2010, 02:53 PM
DRRXR's Avatar
Reach behind the fuel bowl and grab the shield and pull it off of the fuel pump. Check the hoses there for leaks. If no leaks to the right of the fuel bowl there a a fuel filter pressure sensor, made of black plastic and metal. It can leak. When you find the leak post back for more help. I hope its not the btm of your fuel bowl but if it is we can help you jimmy that too.
It may help to wipe everything clean first.
7.3 (1999) Fuel Bowl Leak Natalie7.3 1999 - 2003 7.3L Power Stroke Diesel 9 10-03-2015 10:18 PM
7.3 hpop problems Hvences 1999 - 2003 7.3L Power Stroke Diesel 12 04-24-2015 06:14 PM
1997 7.3 diesel leaking 1997f2507.3 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-16-2015 01:55 PM
7.3 idi oil leak HELP firegod75 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 02-03-2015 03:29 PM
fuel leak on filter housing 1990 7.3 tractormom 1999 to 2016 Super Duty 0 05-25-2014 08:02 PM
Tags
1995, 2001, 73, bad, diesel, f350, ford, high, injector, leaking, oil, pan, powerstroke, pressure, pump, regulator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
