1995 7.3 is leaking oil bad please help!!!!!! - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-04-2010, 04:43 PM
scatgo's Avatar
scatgo scatgo is offline
scatgo is gaining momentum as a positive member of FTE.
Wipe it dry then put a little flower or powder in there. the powder will help find the leak if you have any problems with that.
Old 04-04-2010, 10:31 PM
Jacksfirstdiesel Jacksfirstdiesel is offline
Jacksfirstdiesel is starting off with a positive reputation.
Quote:
Thats a pretty good trick Scatgo. How much flour do you use? I suppose if you get biscuits you used too much. I wish I thought of something like this a couple weeks ago since it took me quite a while to find a fuel leak. It turns out it was coming from the bottom of the FPR.
Old 04-04-2010, 10:43 PM
scatgo's Avatar
Biscuits hu? LOL, yea just dust it. It can help. Sometime the fuel is hard to see. The baby powder or flour will help. You can also dust it on after the leak starts and it will stick to any fuel or oil and show up wet. O yeah and if you ever have trouble finding it on a fat chick roll her around in some flour then look for the wet spot!
Old 06-19-2014, 08:26 PM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
My high pressure lines are leaking yaaaaaaaa.
1/4 tank fuel 10 miles
Old 06-19-2014, 09:59 PM
Robbieo11's Avatar
Well never thought i would say this but my hose ok i blew an oring lol
7.3 (1999) Fuel Bowl Leak Natalie7.3 1999 - 2003 7.3L Power Stroke Diesel 9 10-03-2015 10:18 PM
7.3 hpop problems Hvences 1999 - 2003 7.3L Power Stroke Diesel 12 04-24-2015 06:14 PM
1997 7.3 diesel leaking 1997f2507.3 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-16-2015 01:55 PM
7.3 idi oil leak HELP firegod75 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 02-03-2015 03:29 PM
fuel leak on filter housing 1990 7.3 tractormom 1999 to 2016 Super Duty 0 05-25-2014 08:02 PM
Tags
1995, 2001, 73, bad, diesel, f350, ford, high, injector, leaking, oil, pan, powerstroke, pressure, pump, regulator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
