Super Duty -rear spring conversion
on
Super Duty -rear spring conversion.
iv read this a couple times;
rear SD springs bolt right in place of the stock springs, all you have to do is drill out the front hanger for the larger spring bolt
the question is,
the purpose for this conversion is "mainly" done to improve the ride quality.being longer springs,is what improves it.
so if the springs are longer,i don't understand how the perches are supposed to line up?
by the sounds of the line above,it's like the springs are the same length,and just require larger (reamed out) holes for larger bolts or something.
now,am i crazy or,when i go to measure--leaving the rear perch is the same location-- i see the SD spring perch will need entire new holes further up.in fact,it looks like i'll need to re rout the e-brake cables just a little.
what am i missing here?
these come off an 03 or an 04 SD im pretty sure.i'll post pics before i start getting my old perches off,dont worry.
iv decided on keeping 6 of the mains.i figure being longer,thus a better ride,will be worth keeping the 6 long ones.
i'll need a new center bolt and U-bolts.
the running around for parts for my fuel tank,and fabricating a bit took me all day lol.so i didn't get a start on this.
i did stop in and grab my other BUDD rim tho!
when i run after my new centers and U's i'll grab a 45 for my exhaust.im gunna tilt that 90 i have at a 45 and use the other 45 to get me out.this keeps me low enough to clear the frame.cut a short 3.5 section,toss in a hanger,and then shoot another exhaust clip for fun. peace and quite in the cab again here we come.....thank the maker! lol.
oh the tank;
replaced my 23 gallon poly (front) for another just like it.
filled her up,and checking my mileage now.50 miles so far,and not yet down to F mark.
more than a couple gallons at a time and no more diesel trail........im moving on up.
the question is,
oh the tank;
on
oh man.i shoulda snapped a pic or two of my overload 4 pack.
that SD overload i wanna toss on top of them to make it a nice 5 pack.
see,the reason im not going with so many mains like in these pic,is cus it would ride like a buckboard.no thanks lol.
(i scored these free when i got my dump bed! he cut the frame off,and i took the whole works home.)
i grabbed 4 pics of those,so i may as well post the last one;
on
yeah,that's what i figured needed to be done here.how else ya gunna put longer leafs on right lol.if they bolted in the same location,they wouldn't be longer and give a better ride.
the wording was odd and making me over think things.....i think lol.
oh man.i kinda wish i didn't fill the new tank now.last thing i wanna do is drill into it lmao.
i shoulda done this in a different order.
on
why would it bring me up LCAM?
2" rear lift is out of the question.id have to stay stock springs.im not trying to sit this whole 10 main in.just 6 of them.
im not going to sit them on a 4" block.just the same 2".
does anyone have a write up on this conversion? things aren't adding up here at all.
remeasuring the lengths today,i do see they are close to the same.
being so,im not sure what makes it worth swapping them.i do like the tuffer looking spring hangers over stock.but im not understanding ride quality improvement.
im tempted to just go and have my overload spring pack put together and get new U-bolts and be done with this lol.
but im not gunna pass on a good opportunity for an upgrade.
i'll wait for more info before i get the torch out.
on
not F-Superduty (F-450 equivalent) but Super Duty as in 99-04 F250/350 leaf springs guys.
not having any luck with my exhaust either today lol.been a worthless day here.
least its been nice driving around for parts with a truck that doesn't leak fuel anymore.
heres a little info on what im trying to do:
https://www.ford-trucks.com/forums/8...rovements.html
working on the REAR.
latter id like to do the front too,only if i can find a way to keep stock height..but nothing of concern to me right now.
I am confused by your post.
The pics you showed are from a F-superduty or a F450/F550(99-07) CAST HANGERS!! are a dead give away
They will NOT ride better than your current springs, Is your truck a cab-n-chassis? If so your springs are only 2.5" wide
If you use Superduty springs(99-07 F250/F350) they will ride better than OBS(old Body style) springs. The B codes ride the best
About the '99-up SuperDuty springs, I dunno, I do have some leafs off one of them trucks inserted in my factory leaf packs, but I cut them down to size and have no idea how they would work in place of the factory springs...
TxFireman1972
1999 to 2016 Super Duty
58
03-04-2021 10:23 AM
LeoJr
11-26-2012 01:15 PM
xdevdogx
03-13-2012 08:24 AM
RhondaBruce
07-16-2010 07:27 AM
FORDF250HDXLT
03-15-2010 06:19 PM
