Horn and cruise
Horn and cruise
Here is the description from the service cd.
__________________________________________________ __________________________________________________ _
Contact Assembly (Clockspring)
The contact assembly provides electrical interface between the steering column (3C529) and the control switches in the steering wheel.
__________________________________________________ __________________________________________________ __
Your steering wheel rotates and your steering column is stationery. The clockspring is what is used to make the electrical connection between the switches in the steering wheel and the steering column.
Do you have an factory anti-theft system or keyless entry system? If you do then the horn should still work when you press lock twice on the remote key fob. It should also work when your anti-theft system is triggered.
If the above is true I would think that your clock spring in the steering column is broken since the horn would still work for the anti-theft and keyless entry.
