Is it difficult to replace the RH drag link?
Old 04-01-2010, 05:19 PM
alvald83's Avatar
alvald83
alvald83 is offline
Just took my '69 F250 to the allignment shop today and was told that the Rt side drag link needed to be raplaced as well as the radius arm bushings. The $600 price, was a little too much for me to handle right now.
Is this something that a home (wanna be)mechanic can do on his own.
The drag link seems straight forward if nothing is pressed in. As far as the radius arms are concerned, im not sure if you can remove the bushing brackets and replace them that way. Does an allignment have to be done?
Any advice would be great. Al
Old 04-01-2010, 10:36 PM
Bill W's Avatar
Bill W
Bill W is offline
With a ball joint separator you can do the draglink yourself, (it's just 3 ball joints) if you can do the drag link, you should be able to do the radius arm bushings too. you will need to have an allignment after your done.
here is a nice tool to buy if you don't have one
Old 04-01-2010, 11:39 PM
Danger_Dave's Avatar
Danger_Dave
Danger_Dave is offline
drag link is easy. takes a half hour of your time and runs about a hundred bucks at any store. alignment can be accomplished with just a tape measure and a 5/8 wrench. toe is all that is adjustable. worn out parts can throw you off while trying to align it, but they have to be pretty bad. and radius arm bushings are not one of these things that has anything to do with an alignment. the drag link yes, radius arms, no. they stop horizontal shock and provide stability for the ibeams. they always pull that crap because they want $.
you are really better off doing all of this yourself.
Old 04-02-2010, 12:17 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Radius arm bushings do have a lot to do with alignment- they keep the beams from twisting, and from moving fore and aft. If the beams can move around, then they cannot set the alignment properly.
Old 04-03-2010, 05:23 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
$600.00 is outrageous. What's the name of that alignment shop...Ben Dover Motors?
The draglink (there's only one * on the right [passenger] side-marked: C5TA-3305-A) is the same: 1965/70 F100/250 2WD & 1971 F100/250 2WD before serial number M00,001.
The radius arm bushings (C5TZ3B203C & D) are the same: 1965/74 F100/250 2WD & 1969/74 Econoline.
All these parts can be bought from autoparts stores for less than 150 bucks.
* The left (drivers) side has a short tie rod end.
Old 04-03-2010, 09:43 AM
alvald83's Avatar
alvald83
alvald83 is offline
Besides the ball joint separator, are their any specials tools that i'll need?Thanks for the great info. Al
Old 04-03-2010, 10:54 AM
Bill W's Avatar
Bill W
Bill W is offline
other than the 1.1/8 inch wrench for the radius arm bolt i can't think of any....
Old 04-03-2010, 01:40 PM
xstrange's Avatar
xstrange
xstrange is offline
I need to replace the radius arm bushings on my '67 F100 too. I haven't gotten around to it yet.
Does anything else have to come apart to get them out? Do I just take off the nut and shift the I-beam forward to get the end of the radius arm out of the bushing? Or, do I have to unbolt the radius arm from the I-beam, or do anything with the spring?
I'm just trying to get a handle on how much of a job it is.
Old 04-03-2010, 01:48 PM
Bill W's Avatar
Bill W
Bill W is offline
If your truck has spring retainers holding the spring in the bucket (the two bolts by where the top shock mount is) you might have to remove them to let your Ibeam swing down and forward enough to get the radius arm out..... but, i dont think anything else has to come apart.
nwjones18
09-20-2016 08:57 AM
72CC428
08-08-2016 07:35 PM
'94IDITurbo7.3
16
07-02-2012 07:13 PM
Kickinbass23
08-05-2010 02:47 PM
jad
1978 - 1996 Big Bronco
11-11-2002 09:27 AM
Quick Reply: Is it difficult to replace the RH drag link?
