Is it difficult to replace the RH drag link? - Ford Truck Enthusiasts Forums
Old 04-01-2010, 05:19 PM
alvald83 alvald83 is offline
alvald83 is starting off with a positive reputation.
Just took my '69 F250 to the allignment shop today and was told that the Rt side drag link needed to be raplaced as well as the radius arm bushings. The $600 price, was a little too much for me to handle right now.
Is this something that a home (wanna be)mechanic can do on his own.
The drag link seems straight forward if nothing is pressed in. As far as the radius arms are concerned, im not sure if you can remove the bushing brackets and replace them that way. Does an allignment have to be done?
Any advice would be great. Al
Old 04-01-2010, 10:36 PM
Bill W's Avatar
Bill W Bill W is offline
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
With a ball joint separator you can do the draglink yourself, (it's just 3 ball joints) if you can do the drag link, you should be able to do the radius arm bushings too. you will need to have an allignment after your done.
here is a nice tool to buy if you don't have one
Old 04-01-2010, 11:39 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
drag link is easy. takes a half hour of your time and runs about a hundred bucks at any store. alignment can be accomplished with just a tape measure and a 5/8 wrench. toe is all that is adjustable. worn out parts can throw you off while trying to align it, but they have to be pretty bad. and radius arm bushings are not one of these things that has anything to do with an alignment. the drag link yes, radius arms, no. they stop horizontal shock and provide stability for the ibeams. they always pull that crap because they want $.
you are really better off doing all of this yourself.
Old 04-02-2010, 12:17 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Radius arm bushings do have a lot to do with alignment- they keep the beams from twisting, and from moving fore and aft. If the beams can move around, then they cannot set the alignment properly.
Old 04-03-2010, 05:23 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
$600.00 is outrageous. What's the name of that alignment shop...Ben Dover Motors?
The draglink (there's only one * on the right [passenger] side-marked: C5TA-3305-A) is the same: 1965/70 F100/250 2WD & 1971 F100/250 2WD before serial number M00,001.
The radius arm bushings (C5TZ3B203C & D) are the same: 1965/74 F100/250 2WD & 1969/74 Econoline.
All these parts can be bought from autoparts stores for less than 150 bucks.
* The left (drivers) side has a short tie rod end.
Old 04-03-2010, 09:43 AM
Besides the ball joint separator, are their any specials tools that i'll need?Thanks for the great info. Al
Old 04-03-2010, 10:54 AM
Bill W's Avatar
other than the 1.1/8 inch wrench for the radius arm bolt i can't think of any....
Old 04-03-2010, 01:40 PM
xstrange xstrange is offline
xstrange is starting off with a positive reputation.
I need to replace the radius arm bushings on my '67 F100 too. I haven't gotten around to it yet.
Does anything else have to come apart to get them out? Do I just take off the nut and shift the I-beam forward to get the end of the radius arm out of the bushing? Or, do I have to unbolt the radius arm from the I-beam, or do anything with the spring?
I'm just trying to get a handle on how much of a job it is.
Old 04-03-2010, 01:48 PM
Bill W's Avatar
If your truck has spring retainers holding the spring in the bucket (the two bolts by where the top shock mount is) you might have to remove them to let your Ibeam swing down and forward enough to get the radius arm out..... but, i dont think anything else has to come apart.
1988 2wd F-150 Violent Brake Shaking nwjones18 1987 - 1996 F150 & Larger F-Series Trucks 14 09-20-2016 08:57 AM
FRONT END BUSHINGS, GREASE CUPS, ETC... 72CC428 1967 - 1972 F-100 & Larger F-Series Trucks 2 08-08-2016 07:35 PM
Radius Arm Bushings '94IDITurbo7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 07-02-2012 07:13 PM
Loose steering.. replace pitman arm with drag link? Kickinbass23 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-05-2010 02:47 PM
drag link bolt 1972 F-100 Explorer Package yellow72f100 1967 - 1972 F-100 & Larger F-Series Trucks 1 07-10-2006 05:29 PM
Tags
05, 1997, 2002, 2006, drag, econoline, econolinehow, escape, f100, f350, ford, link, ranger, replace, replacing, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
