ford 370 runs bad please help
Hi I have a 1980 f 700 or f800 not sure but it has the 370 engine in it. It runs bad very bad. found cylinder 3 4 and 7 are not fireing ive checked all the basics and it is kicking my butt. it has 160 psi comp, plug is black, swapped plugs, wires, and cap with known good parts, vac is low 17 but fairly steady and now im lost??
well the carb that came on it was leaking fuel from sitting for a whyle so its got a newer carb that came off my mustang which has become my parts car, and it ran fine befor i parked it last fall so I would like to assume its good? but 4 of the plugs are golden brown one is dark brown and 3 are black?
It has new wires new plugs new cap new rotor newer carb I even swaped the plugs and wires and cap (wouldnt be the 1st bad part out of box that ive got) . problem stayed in the same cylinders 3 4 and 7. I have a spark tester that goes in line and it lights up as bright as the cylinders that are working. it dosnt just pop once it pops alot. kinda reminds me of a rev limiter just its poping out the carb
370 Problems
370's sometimes leak around the intake gasket and lean down certain cylinders. If you have good compression then mechanicaly the heads are OK.
Check for vacuum leaks ,also if you have vacuum boosted brakes the booster could be leaking or the resevoir or lines could be bad.
Have A Good Day-----------Hotwrench
Thanks alot for all the good tips, now what do I do with the cam? I bought the truck in boxes tore down the eng and found the oe cam worn down didnt think much of it it is a 1980 dump truck put back together and now it has wasted a nother cam ( truck hasnt ran more than 2 hours max and has 0 miles) Just bad luck? or something wrong???
