a/c compressor change, what type OIL and how much ? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-01-2010, 03:54 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
after 300k rounds, my a/c compressor is not quite right. Having clutch issues and just gonna change the entire thing, along with the accumulator and orifice tube. BUT, I cant find what type of oil i need or how much. I have PAG oil, will this work ? and how much ?
Old 04-01-2010, 04:17 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Depends on what refrigerant you're going to refill with.
If the crappy r134a, then you have to use an equally crappy PAG oil as r134a is NOT compatable with mineral oil.
If it were me, I would spare no expense when it comes to PAG oil. The stuff is a marginally adequate (or inadequate?) lubricant and I would do a LOT of research to find out if there is a brand or formulation that is better for our systems. Much like you're doing here!
The stuff Ford used at the factory back when these trucks were built seems pretty darned good. If only we had a way to know what it was!
Old 04-01-2010, 06:41 PM
yup, 134a. how crappy of pag oil do I need ? anything specific ? I am gonna replace the compressor tonight and would like to get this all done at once. Thanks for the original answer, as vague as it was, still had humor to it.
adding oil to the A/C compressor Frzrfxr 1987 - 1996 F150 & Larger F-Series Trucks 2 08-23-2013 06:37 PM
Rudamentary A/C repair questions jboehm 1987 - 1996 F150 & Larger F-Series Trucks 50 05-05-2013 08:50 PM
1978 Mercury A/C Questions Rusty_S Cooling, Heating, Ventilation & A/C 9 06-07-2011 10:35 AM
A/C compressor bad? mjbll 1997 - 2003 F150 1 03-29-2010 05:07 PM
How much A/C oil mchild Cooling, Heating, Ventilation & A/C 2 07-05-2009 07:20 AM
Tags
2000, ac, change, changing, compressor, f250, ford, mineral, oil, orfice, pag, quantity, ranger, trucks, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
