Clutch Master Cylinder Now with pics! - Ford Truck Enthusiasts Forums
Old 04-01-2010, 12:48 PM
diesel_daze_ray's Avatar
diesel_daze_ray diesel_daze_ray is offline
diesel_daze_ray is starting off with a positive reputation.
Howdy ya'll,
Clutch went bang an shot to the floor in a busy intersection yesterday. After getting towed home along with my tool trailer, I went in search of the issue. Lo and behold, its the plastic end on the pushrod to the master cylinder. I have been looking at different places and calling about prices. The local dealership wants 170.00(not in stock), a not so local dealership wants 155.00. Napa and others want around 55.00 to 65.00 bucks for theirs. This concludes givin' ya'll the skinny. What do those of ya, 'in the know', think about this?
http://www.ford-trucks.com/forums/pi...ictureid=30992
http://www.ford-trucks.com/forums/pi...ictureid=30994
http://www.ford-trucks.com/forums/pi...ictureid=30990
Update: I bought the NAPA one and it appears the electrical connection doesn't fit onto the new one. I guess its off the not-so-local-dealership.
Last edited by diesel_daze_ray; 04-01-2010 at 06:58 PM. Reason: No response Circumstances changed
Old 04-01-2010, 08:20 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
That is exactly what happend to me about a month ago. Here's the bad news. Just replacing the rod most likely wont be an option. I could not for the life of me remove mine. I had to buy a new clutch master cylinder. Wait, it gets better, someone redesinged the clutch master so that the hose you have will not connect to your new clutch master. Now you have to buy a new hose as well. Since I was replacing the master and the hose I got a new slave cylinder as well so that everything would be new. Dont get your parts from the dealership, I got everything I needed from Schucks/O'reilly's for a lot cheaper.
Here is the new CMC next to the old one.
The neutral safety switch fit on the unit I got from Schucks.
Old 04-01-2010, 09:20 PM
the switch threw me off. i managed to look into it farther and the guys at napa found me the right one, down tube and all. it was listed under an f350. the first one i got had the line coming straight out.
it kills me when i need answers quick, fast and ina hurry, when i know everyone is at work and i should be too. i don't make much money sitting at home.
as it turns out the master is leaking at the firewall, so it was on its way anyhoo.
Old 04-02-2010, 01:54 AM
Wow, you got lucky. I had people searching high and low trying to find an old style CMC, I even went to ford to ask them what the deal was. Thats when they told me about the redesign and why I couldn't find the CMC I wanted.
Make sure you bench bleed your new CMC, I have found that just installing it and trying to pump the pedal doesn't always work. The pedal may not travel far enough to get it going.
Old 04-02-2010, 09:56 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Don't waste to much time bench bleeding these things. If you can get it in gear, go for a drive on a rough road. The bumps will work up all the air bobles out of it, then just add fluid and your good.
Old 04-02-2010, 11:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
If you get one made from metal, fill it up and pump all the fluid out.
I do this on both clutch and brake master cylinders now.
If you catch the fluid in a clean container, you may be surprised at what you catch in it.
I have seen over 1/4" of metal shavings in a coffee cup from a brake master cylinder.
Wonder whay the seals wear out so fast?
Old 08-17-2013, 01:15 PM
Craig1967 Craig1967 is offline
Craig1967 is starting off with a positive reputation.
Thumbs up CLutch Master CYlinder
I have this same problem. 1993 F350 dually and clutch went to floor. I just bought a new CMC for $38 at Oreilly's. Came with pushrod and retainer rod as well. Going out to change it.
I don't understand how it connects to the pedal. Instructions in rebuild manual say to "pry" it loose.
I did see a youtube video on a fix a guy did for that plastic retainer on the end oft he pushrod. I have to admit it looks junk.
Wish me luck. Will be back in shortly to see what it has turned out as
Craig-
Montrose, IA
Old 08-17-2013, 03:39 PM
Doggoneit!
It's the slave cylinder. Can see fluid leaking out. Not looking forward to pulling this tranny by myself.
Old 08-17-2013, 07:19 PM
Rxracer27 Rxracer27 is offline
Rxracer27 is starting off with a positive reputation.
pulling the trans to fix the slave? why?
just pop it off the bracket. I sourced most of my clutch parts from autozone. IIRC they had the old style stuff and that was as of about a year ago. i justhad to go to the junk yard for the hose.
Rob
Old 08-17-2013, 08:14 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
Yeah, none of the IDIs have an internal slave, no matter what transmission they have behind them.
The slave just clips onto the bell housing.
A word on bleeding the system:
http://www.ford-trucks.com/forums/12...l#post13279495
Old 08-17-2013, 10:35 PM
hmmmmm
Wow, the book I bought today, as well as the Oreilly's guy, says you have to pull the tranny because the slave cylinder is around the shaft. Not sure what IDI means. Anyone want to explain it.
Old 08-17-2013, 11:28 PM
engine
my f350 has a 302 Modified in it with a 5-speed. You guys sure it doesn't have internal slave cylinder?
Old 08-18-2013, 09:25 AM
You are in the wrong forum then, this is the 6.9 & 7.3 IDI Diesel forum.
The forum for lil' putt putts is over here:
Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums
2011 FTE '57-'96 General Championships ~ Round-1 76f350spercamprspeal Picture competitions 16 02-08-2013 04:40 AM
2011 FTE Diesel Championships ~ Round-1 76f350spercamprspeal Picture competitions 59 01-25-2011 04:46 PM
2010 FTE Diesel Championships Round-8 76f350spercamprspeal Picture competitions 76 09-06-2010 02:07 AM
2010 FTE '61-'79 Classic Championship Round-8. 76f350spercamprspeal Picture competitions 59 09-02-2010 11:54 AM
2010 FTE FAT FENDERED MOB Round ONE poll Greywolf General Automotive Discussion 78 02-28-2010 09:00 PM
Tags
1986, 1993, brake, c6, clutch, connection, cylinder, f250, ford, master, remove, replace, replacement, slave, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
