Wont shut off
Wont shut off
I turn off the key and remove it. The engine shuts down but everything else stays on, the radio, heater fan, etc. I tried to search the forum but couldn't find anything about this problem. I'm guessing there is a stuck relay or a bad ignition switch. Any ideas??
2000 F450 7.3 PSD automatic 4X4
Thanks .... Ken Gardner
I am assuming this is not the normal "accessory delay." Water likes to leak through the tired front window seal and trickle down into the GEM or fuse box and can cause this type of strange behavior. I would start by looking into those two components for corrosion. A tell-tale sign is wet carpet in the vicinity of the fuse box after it rains.
It seems dry in the area. I will look for problems there however. This is driving me nuts!
Is there a timer for the accessory delay relay? If so where is it located. I checked the relay and it is OK. Actually I replaced it. Also, the blower motor did not run when key was off, my mistake, I thought it had.
Just a thought (again i have a 250 so YMMV....)
I had something like this happen a few times. When i turn my truck off, the radio and other shtuff stay on for a few mins or so, but it immediately turns off when i open my door.
One day i open the door and the radio doesn't go off... I sat there scratching my head for a while, then it went off, apparently from the timer. Then i noticed that the dome light wasn't going on when i open the drivers door... turns out the "door ajar" switch is in the latch, and it was getting stuck. A squirt of wd-40 and all was right again. (Door closes easier too).
pgoss8
03-21-2017 12:03 AM
