Bigger cam in 5.0l with SD
Old 04-01-2010, 09:33 AM
BlueOvalBoy19's Avatar
BlueOvalBoy19
BlueOvalBoy19 is offline
I have a 5.0l an im putting a comp cams .456 lift an gt40 heads as well an im just wondering if i should put bigger injectors. possibly 24lb?
Old 04-01-2010, 09:47 AM
Conanski's Avatar
Conanski
Conanski is online now
Is the cam SD friendly? What is the grind number.
Bigger injectors are not needed nor can the SD EFI system handle them.
Old 04-01-2010, 11:13 AM
darthice's Avatar
darthice
darthice is offline
use the cam in pauls sig it is the best one for a sd setup
Old 04-01-2010, 12:37 PM
lew52's Avatar
lew52
lew52 is offline
What year is your truck ?? Is it a roller motor ??.....Lew
Old 04-01-2010, 03:47 PM
capn kirk's Avatar
capn kirk
capn kirk is offline
you can get a chip for SD so it can work with what you do to it
Old 04-01-2010, 03:50 PM
darthice's Avatar
darthice
darthice is offline
ewww i hate chips you can get good performance out of your truck just by changing the cam to the one in pauls sig and putting on a freer flowing exhaust
Old 04-01-2010, 04:07 PM
lew52's Avatar
lew52
lew52 is offline
A custom burned chip will do any thing you want it to do , the over the shelf chips don't do much of anything . I think Paul would have another cam choice other than the one he has in his 5.0 ......Lew
Old 04-01-2010, 04:08 PM
darthice's Avatar
darthice
darthice is offline
yeah but those custom burned chips are HIGH DOLLAR
Old 04-01-2010, 04:13 PM
lew52's Avatar
lew52
lew52 is offline
Yeah you get what you pay for , if you want your truck to do what you want it to do it costs $$$$$......like around 600 for a EFI auto set up on a dyno .....Lew
Old 04-01-2010, 04:23 PM
darthice's Avatar
darthice
darthice is offline
Honestly i would much rather get a programmable MAF setup for the amount you would spend on the custom chip. I have been thinking of even converting my truck to OBD-II just because i like doing stuff like that
Old 04-01-2010, 04:41 PM
lew52's Avatar
lew52
lew52 is offline
You can use the PRO M mass air meters set to your injector size with out a tune , but with a good tune there that much better , i would stay OBD I
Old 04-01-2010, 05:06 PM
capn kirk's Avatar
capn kirk
just to clarify i was talking about a custom chip
i was just saying that you could go to a bigger cam if you wanted but you would need a custom burned chip
Old 04-01-2010, 08:05 PM
BlueOvalBoy19
mine is a 1987 f150 but it has a 90 motor. its not a roller.
Old 04-01-2010, 08:06 PM
BlueOvalBoy19
i know a better place to get a custom chip Blueovalchips.com
Old 04-01-2010, 08:07 PM
BlueOvalBoy19
well according to jegs it is lol. What if i got bigger injectors an tuned it? would the SD work then?
Quick Reply: Bigger cam in 5.0l with SD
