Need help with 2006 Expedition front brakes - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 04-01-2010, 10:02 AM
pgonza2723 pgonza2723 is offline
pgonza2723 is starting off with a positive reputation.
So I went to replace the front pads yesterday and ran into a sticking point. It appears I don't have the correctly sized hex to get off the caliper sliding pins on the back side of the caliper.
Does anyone know the size of these? I tried 8mm, 5/16 which were too small and 10mm and 3/8 seemed to be too large. Also, is it good practice to replace these as well? Slightly frustrated at this point. Thanks for any help on this.
Old 04-01-2010, 11:55 AM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
Wouldn't that leave 9mm?? Damn, should have bought the 15pc. hex key set!
Old 04-01-2010, 12:51 PM
Yea, I assume that.... but you know what they say about assuming
Old 04-01-2010, 01:34 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Yes it's a 9mm, which most hex set do not have. If you have a Sears nearby, you can go and get one from them.
Old 04-01-2010, 02:18 PM
You always seem to come through Alloro... Thank you sir!
Old 04-01-2010, 05:29 PM
Quote:
Sorry, I can't help it, it's a curse.
Kragen auto parts stores also carry it if you have one near you.
http://www.sears.com/shc/s/p_10153_1...00010000100600
Old 04-01-2010, 11:51 PM
Well two of the Sears and all auto parts stores don't have it along with harbor freight and tractor supply. Guess I have to wait until one comes in the mail . No kragens here BTW
Old 04-02-2010, 12:32 AM
go_phx go_phx is offline
go_phx is starting off with a positive reputation.
If you remove the entire caliper the slides come apart without removing those slide bolts. It's a bit tougher to put back together with the outside spring clips, that darn internal spring inside the caliper and the pads...but patience will make it work.
Old 04-02-2010, 11:48 PM
If you don't want to wait...go to a hardware store, get 2 bolts with 9mm heads and 4 nuts to fit the bolts. Screw two nuts on to the ends of each bolt, then tighten them together real tight. Now you can stick the head of the bolt into the caliper bolt and use a socket or wrench on the nuts to spin it out.
Old 03-09-2012, 12:51 AM
jfaber jfaber is offline
jfaber is starting off with a positive reputation.
Home depot. The Huskey 13 & 26 piece kits include a 9mm Hex Key.
<!-- google_ad_section_end -->
Allen Bolt Size on 2008 Expedition EL Front Brakes dhearn 2007 - 2014 Expedition & Navigator 4 12-17-2014 01:23 PM
2006 Eddie Bauer Expedition caliper bolt size...it's NOT 9MM cs641 Expedition & Navigator 0 07-04-2014 10:19 AM
Questions on Escape brake replacement SIXD9R Escape & Escape Hybrid 9 06-09-2014 07:02 PM
Help what size nut is the yoke nut? powerstroker100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-12-2010 03:48 PM
Expedition Brake Caliper/ pad repair rjnjamie Expedition & Navigator 10 09-16-2008 03:05 PM
Tags
2006, 2008, brakes, calipers, change, expediation, expedition, ford, front, needed, pads, remove, removing, tool, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
