How do I check my block for cavitation?
Old 03-31-2010, 09:29 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
I am about to pull my 7.3 that I think blew a HG.
How do I make sure that it has no cavitation?
I am afraid of getting it all put back togather with new parts just to find the block leaks.
If the block is good I am about a week away from my IDI being on the road.
Old 03-31-2010, 10:11 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
uh oh Bill.
your not going to like your v10 as much any more lol.
Old 03-31-2010, 10:18 PM
starmilt's Avatar
starmilt
starmilt is offline
Bill if you are pulling the motor anyway, the best way is to pull the pan and pressurize the cooling system and see where the leak is coming from. I would fill the radiator and pressurize each cylinder through the glow plug holes, before I pulled it the one or ones that overflows the radiator is going to be the cylinders to check.
Old 03-31-2010, 10:21 PM
bill11012's Avatar
bill11012
We'll see.
I don't hope for it to pull like the V10, it has around 100 less HP and 100 less TQ.
If it can get good fuel mileage then I will start using it on trips that I don't need to tow as much and/or run 75 and 80 towing to get there on time.
Joe says the IDI will pull harder than the V10, but I think he's just going crazy from being in California so long.
Old 03-31-2010, 10:25 PM
bill11012's Avatar
bill11012
Ok, and then after I pull the heads, If the HG does not look bad around those cylinders how do I check the block?
Old 03-31-2010, 10:32 PM
starmilt's Avatar
starmilt
starmilt is offline
After you pull the motor, pull the pan and pressurize it and if it is cavitation you should be able to see where it is, do this before you pull the heads.
Old 03-31-2010, 10:39 PM
bill11012's Avatar
bill11012
Ok, so pull the pan, leave the heads on and blow air in through the glow plug hole.
What keeps the air from pushing the piston below the cavitation hole?
Happy birth day BTW. Face book sent me a message saying it was this week.lol
Old 03-31-2010, 10:47 PM
starmilt's Avatar
starmilt
starmilt is offline
OK block off the water hose ports and pressurise the cooling system, while the pan is off.
It would be nice to be able to remove the pan while the engine is still mounted, but this is a pain.
If you have water coming out by the piston, you can now turn the motor by hand to get that piston to the top, then pressurise it again if the pressure rolls the piston back down it is usually a head gasket, and usually if it is cavitation it is obvious.
Old 03-31-2010, 10:52 PM
bill11012's Avatar
bill11012
Ok, that makes since.
I will pull it in the next 2-3 days and let y'all know what I find.
If its real bad I will post pics.
I am going to put it on a stand, so testing it should be easy.
Old 03-31-2010, 10:59 PM
joe f350's Avatar
joe f350
joe f350 is offline
i said a turbo idi wile ur at it y not pull that v10 its just a boat anocher
Old 03-31-2010, 11:03 PM
FORDF250HDXLT
80 mph while towing.........ok your going to like the v10 then lol.
jeeze,im glad im not buying your fuel.ouch.
Old 03-31-2010, 11:06 PM
starmilt's Avatar
starmilt
starmilt is offline
If you have the tires to handle the weight your towing, 80 isn't out of the question.
Old 03-31-2010, 11:31 PM
bill11012's Avatar
bill11012
I have made a hand full of trips at 90. That drops the mileage as low as 6-7.5.
I used to do that when I had to much stuff to haul and not enough time.
Got one 88 in a 70 ticket and that hurt bad enough I try to not do that as much.
Old 03-31-2010, 11:33 PM
bill11012's Avatar
bill11012
It runs great, Why would I pull it?
Just so you know, I will out pull an other wise stock turbo IDI.
Old 03-31-2010, 11:59 PM
joe f350's Avatar
joe f350
joe f350 is offline
yea right i should start a idi vs v10 tread in the stupid duty fourms lol
Quick Reply: How do I check my block for cavitation?
