CAT like the Torqshift!
CAT seems to be very interested in using the Torqshift transmission in some of thier equitment. I think the Torqshift has caugh Allison and past them. But I have no knowledge of Allison transmissions. I know that the Allison uses a 3 peice case and the Torqshift use a one piece one. Just thought you guys might want to hear about this I thought it was pretty cool. Go Ford!!!
See, the thing about Allison is that the transmission used in the GM pickups isn't the transmission used in heavier vehicles. While it is still a decent transmission, it's reputation relies on the good service provided by the heavier transmissions.
The Torqshift had no corporate name to ride into glory. It had to prove itself as a reliable transmission, which it has.
Now, if CAT does mate a medium duty engine to the 5 or 6 speed Torqshift, it may be good news for those of us who may want to drop a Cat engine into a Super Duty.
Secondly, do you know what ACERT is? ACERT = Advanced Computer controlled Emissions Reduction Technology. This is Caterpillars genius method of getting around EGR for the 2004 engines.
ACERT is a complex system that uses two turbos, a variable lift valvetrain, and some expensive and complex electronics to make it all work. ACERT is the reason Caterpillar stopped making engines! The system was reliable after awhile, but like our much maligned 6.0 the first couple years destroyed their credibility within the industry. ACERT is why their market share dropped to below 10% and they stopped making engines.
Why would anyone want a one in a pickup?
It isn't going to happen. CAT's already got their own in house auto out there and they are getting out of the heavy duty segment for now. There will be a Cat branded truck out there but it will had a CAT built slush box behind it and it's a ways out. There is no way a Torque shift could handle a C7, 860 ft lbs of torque and a 33K lb GVW would be the end of the trans in about 25K miles.
I've drive a C12 / Cat Auto combo and it moves out for what it is, while it's no match for a C15 550 hp w/ a 13 spd it's runs good.
Furthermore, the 5R110 is standing up pretty well behind modified 6.4s which are pushing at least 850 ft-lbs of torque. The new 6R140 is a significantly stronger design.
What makes you more qualified to answer this than the engineers who designed the tranny? It's been in use, rated for 33K GVWR since 2003....
Funny you mention that. Because 33,000 lb GVWR is exactly what the TorqShift is rated for in an F-550.
Are you serious? First off, the C7 is only rated for 300HP@2400 RPM/860 ft-lbs@1440 RPMs. So unless you were replacing a 7.3 which never used the torqshift you would be taking a step backwards in power. It also weighs 450 lbs more than a PSD.
I live in CT which has emissions testing for diesels, so compliance is an issue for me. What I was thinking is that it may be easier to have an "emissions legal" modified older(pre-DPF) Cat engine mated to the 6R140, that's all...
The other problem is that OEM truck manufacturer are vertically integrating with the other truck engine OEMs. This is why our market share in engines when below 10%... Navistar is now going strictly Cummins I believe, Freightliner was Detroit diesel, Mack makes there own stuff ( and always has), PaCar is geting engines from overseas, Western Trucks went Cummins. No one integrated with CAT, and we didn't want to. Honestly, CAT did not make much from the sale of truck engines. After all the R&D, we were lucky to break even. We stayed in the market because we could lead it, and our customers and the stock market expected us to. Now, it's changed. and we have new global engine producers that can beat us on price, by a big margin.
How do i know this? I work at the Mossville engine plant where they are made! I get to hear all the stuff.
Don't worry, I'm not telling you anything that is not already public information. No insider trading problems here.
Edit: Why would anybody want one? Because they are the longest lasting, most reliable engines made!, of course! ( but I bleed CAT yellow, and have ford blue in my viens). A Superduty with a cat engine would be right up my alley, IMO. Wait wait... the 7.3L is HALF CAT anyway, with the HEUI injectors and fuel system!. Whoo hooo. Lets see now, 7.3L PSD are Legendary, and CAT quality is Legendary, Seems like a perfect fit. No CAT input to the 6 leakers, or the 6.4, and they had or are having problems with them in one fashion or another. Think about that.....
I think that over 800ftlbs in a superduty at 1400 rpm would be pretty freaken sweet. I'd like ot see how the new torqueshift holds up before I'll pass judgment. I have seen the 5 speed torqueshift trans fail a couple times. A customer had one behind a V10 in an f350 utility body and the trans pooped itself twice in 35K miles.
ACERT did not kill CAT truck engines, the EPA did. 2010 brought a new round of on-highway emissions. CAT did not have time to make a profit on ACERT before they had to re-engineer it again.
The "blame it on the EPA" mantra doesn't quite cut it though. It was December 2000 when the EPA set the particulate and NOx standards for 2007 and 2010. This was before the first ACERT engine rolled off the line. Here's the proof:
http://www.epa.gov/otaq/highway-diesel/regs/f00057.pdf
Originally Posted by EPA Regulatory Announcement, December 2000
We are also finalizing standards
for NOx and non-methane hydrocarbons
(NMHC) of 0.20 g/bhp-hr and 0.14 g/
bhp-hr, respectively. These NOx and
NMHC standards will be phased in together
between 2007 and 2010, for diesel
engines. The phase-in will be on a percent-of-
sales basis: 50
percent from 2007
to 2009 and 100
percent in 2010
sales basis: 50
percent from 2007
to 2009 and 100
percent in 2010
Believe me, there's no love lost between myself and the EPA. They ruined my truck! THEY are the reason I get 12 MPGs!
Anyway, I can understand taking Caterpillar's side when you work for them, I would probably do the same thing. You didn't happen to work there during the second half of 2006, did you? You might have made my C15!
