85 Ford F250 Tailgate Trim. Where to get!
Old 03-01-2014, 04:57 PM
tony_corbin's Avatar
tony_corbin
tony_corbin is offline
86 tailgate trim panel
Just wondering if anyone still has one available? Thanks
Old 08-09-2014, 05:15 AM
BigTiny460's Avatar
BigTiny460
BigTiny460 is offline
I have one
I have one of these panels. Excellent condition If anyone is still interested
Old 08-09-2014, 04:38 PM
dan crowley's Avatar
dan crowley
dan crowley is offline
Smile Tailgate panel
I like to see a picture of your tailgate panel if you can post one. Dan
Old 08-09-2014, 11:56 PM
BigTiny460's Avatar
BigTiny460
Old 08-10-2014, 09:00 PM
quakerj's Avatar
quakerj
quakerj is offline
I used one off a early 90's bronco for my '85 F-250. The only thing that's different is the notch for the tailgate is not there, as the newer gen. Bronco's and F-Series have the tailgate handle mounted up higher. Otherwise the size in the same. I had to cut the notch in with an angle grinder, and I lined the sharp edges with 1/4" vacuum hose. Looks factory-ish, I imagine if you took the time you could make it look flawless.
I can't comment on how it mounts, as I simply used self drilling Tek screws in a few places to fasten it securely. It's been a year and still looks good, much better than the plain painted metal on a Lariat truck.
The only oddity I found, having used a panel from a Bronco, is there's a small hole for what I assume is a lock. I don't even notice it, but if you're looking for it, you'll find it.
Old 07-10-2016, 10:20 PM
gamuman's Avatar
gamuman
gamuman is offline
1986 F-150 Lariat needs red tailgate trim
Hey guys,
I know some of these posts are old however if you still have a red reflector or a whole trim panel for a 1986 F-150 tailgate in good condition, I need one! The 86 model has horizontal grooves down the length of it! Thanks!
Gamuman
Old 07-10-2016, 10:24 PM
gamuman's Avatar
gamuman
gamuman is offline
Hey guys,
I know some of these posts are old however if you still have a red reflector for a 1986 F-150 tailgate in good condition, I need one! The 86 model has horizontal grooves down the length of it! Thanks!
Gamuman
KidAutolite
2017+ Super Duty
06-25-2017 04:14 PM
automaticlee
Paint & Bodywork
02-13-2017 07:32 PM
gamuman
20
08-15-2016 06:18 PM
satx78247
27
04-10-2016 12:03 AM
Absolute
17
03-08-2016 12:24 AM
Quick Reply: 85 Ford F250 Tailgate Trim. Where to get!
