85 Ford F250 Tailgate Trim. Where to get!
I used one off a early 90's bronco for my '85 F-250. The only thing that's different is the notch for the tailgate is not there, as the newer gen. Bronco's and F-Series have the tailgate handle mounted up higher. Otherwise the size in the same. I had to cut the notch in with an angle grinder, and I lined the sharp edges with 1/4" vacuum hose. Looks factory-ish, I imagine if you took the time you could make it look flawless.
I can't comment on how it mounts, as I simply used self drilling Tek screws in a few places to fasten it securely. It's been a year and still looks good, much better than the plain painted metal on a Lariat truck.
The only oddity I found, having used a panel from a Bronco, is there's a small hole for what I assume is a lock. I don't even notice it, but if you're looking for it, you'll find it.
gamuman
20
08-15-2016 06:18 PM
satx78247
27
04-10-2016 12:03 AM
Absolute
17
03-08-2016 12:24 AM
