Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-31-2010, 06:00 PM
tony1947 tony1947 is offline
1947 Ford F-100
tony1947 is starting off with a positive reputation.
Exclamation cam and crank gears reversed on newer flatheads?
another ez question for you guys. I have a 52 V8 block with its original cam in place and I have a ,I hope 4" mercury crankshaft to go in it . The cam gear to the crank gears don't mesh togeter, one is reverse of what it should be. Could the crank gear be on backwards or do I have an older maybe 1948 crank and gear? The crank has the larger oil plug holes and with a ruler I measured 4" throw , but on the old paper tag from a machine shop it says 1939 ford ,along with the under cut measurements. Did the other flatheads have gear teeth reversed from the 49-53? HELP!! tony in buffalo ny
  #2 (permalink)
Old 09-09-2010, 12:27 AM
Overkill-F1's Avatar
Overkill-F1 Overkill-F1 is offline
Garage is empty, add now
Overkill-F1 is starting off with a positive reputation.
I'm not sure what year they changed, but the gears are different. Earlier gears would tend to push the cam into the front cover as it rotated. Later ones (with the different gears) would push the cam up against the block. I hope I got that right !?!?
You can't reverse the gear, it would still be the wrong direction.
...Terry
__________________
It is a simple task to make things complex,
but a complex task to make them simple.
Tags
1948, 226, cam, crank, cranks, flathead, ford, gear, gears, gearscams
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
