Exhaust Manifold Leak with broken Bolts!!!! - Ford Truck Enthusiasts Forums
Old 03-30-2010, 10:56 PM
vlietracer64 vlietracer64 is offline
vlietracer64 is starting off with a positive reputation.
Today while under my 04 F450 dump for an oil change i noticed heavy black carbon over the exhaust manifold and head. On the driver`s side rear exhaust port (cylinder #8) the upper and lower bolt heads are broken off. Now i know why it is leaking but can understand the broken bolt heads. only ever been worked on by dealer, who i would not think would do that, also dont recall any exhaust manifold work ever being done. Anyone know of this being a common problem??? Also,can i get new bolts, and the metal gasket ford offers to repair it, or if it has been leaking for a while would it warp the manifold too much for it to reseal. Thanks Peter G.
Old 03-31-2010, 06:19 AM
anyone ever have this happen?
Old 03-31-2010, 06:57 PM
1_BIGMOFO 1_BIGMOFO is offline
1_BIGMOFO is gaining momentum as a positive member of FTE.
thats weird, it sounds like they broke... this has to be a known problem or something!!
Old 03-31-2010, 07:06 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
you can get the EM gasket set and replacement bolts, no problem. That manifold is easy to remove(don't forget the EBP sensor tube). Hopefully the old bolts come out easily for you. The manifold should be fine.
I worked on a buddy's truck last weekend and the same bolts were loose on his exhaust manifold and leaking.
Old 03-31-2010, 07:08 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
we see it from time to time. not common. we used to get 460's in that way left and right.
Ive seen more 6.4 do it latly. repair wil be basied on the finding if the maniflod is warped.
Old 03-31-2010, 07:32 PM
Thanks for the input guys, just out of curiousity do they sell aftermarket / performance headers for the 6.0's?
Old 03-31-2010, 07:37 PM
Quote:
never seen a set myself.
Old 04-01-2010, 06:38 AM
i have never seen a set either..
Old 04-01-2010, 11:21 AM
TrdLtly's Avatar
TrdLtly TrdLtly is offline
TrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputation
My 04 F350 6.0L (187k mi) is in the shop right now getting one broken exhaust manifold bolt replaced. Mine was/is the passenger top rear bolt. I am having them replace all the bolts on the one side and adding the gasket. They estimated 2 hours for the repair. The book rate is different from passenger side vs drivers side. I believe the drivers side was quicker. Both sides were estimated at 3.5 hrs.
Broken Exhaust Manifold Bolt RedBandit 1987 - 1996 F150 & Larger F-Series Trucks 17 09-14-2014 10:31 PM
Broken Exhaust bolt 390 sunsettractor 1973 - 1979 F-100 & Larger F-Series Trucks 21 08-19-2013 03:10 PM
Exhaust Manifold Studs Broken Causing Leak, PO Drilled Off-Center Super Wagon Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 14 03-10-2013 12:08 AM
Tips on removing Exhaust Manifold bolt?? jimkari 1997-2006 Expedition & Navigator 11 02-06-2013 09:39 AM
Help - FE390 coolant leak from exhaust manifold bolt DutchB100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 04-19-2012 10:19 AM
Tags
2004, 60, bolt, broken, common, excersion, exhaust, f150, f350, f450, ford, leak, leaks, manifold, remove, studs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
