Tips Or Tricks On Bed Removal
Im going to be taking off the bed of my 1995 f150 super cab short box this weekend. Is it just the six mounting bolts I see? Any harnesses that anyone can clue me in on I need to unplug. Going To Rhinoline the box & replace a faulty sending unit.
Thanks For Any Help!!!
if you're going to be rhinolining, I'd suggest welding the bed bolts to the box with a couple tack welds to help them hold them when removing the nuts or you'll risk turning the bolts in the holes in the bed. Since you're lining it, it shouldn't matter that the paint is scratched up.
My truck came apart fine once we welded the bolts in, heated them up real good, and doused them with PB blaster.
^ That's a real good idea. My bolts held great, but when I put the bed back on, the weight of the bed pushed the bolts up and ripped them thru the liner.
There are two connectors around the bumper area. Prolly for the tail lights and the trailer hook up. And yeah, pretty much just the six bolts... And disconnect the fuel fillers from where the cap is. The three 7mm/10mm bolts. There's also a hose clamp holding the filler tubs to the bed underneath.
I did my 6' myself. I just slid it back enough to get to the front tank.
There's some sharp edges, so get some real thick leather gloves. It really had to put some *** into it to get my bed up, off the bolt holes, and to slide it back enough to get to the fuel pump. My 6' bed wasn't THAT bad, just very awkward. When I reinstalled it, I tried just getting underneath it and "benching" it up to get the shims back in... It seemed a lot easier that way, but watch out for falling dust, dirt, and rust that WILL find it's way into your eyes.
when i took my flareside bed off of my truck, it was heavier than expected... we did it with 3 people to be safe and ease it down just rite. if it came down to it two people could do a short box or flareside bed. not too sure about a 8 footer though. the thing that i found out was that the weight of the tailgate made the bed wana tip back when moving it around so that was why the third person was there for me(didnt feel like taking it off)
