95 explorer 4wd problems - Ford Truck Enthusiasts Forums
Old 03-29-2010, 08:02 PM
buckeyes8603 buckeyes8603 is offline
buckeyes8603 is starting off with a positive reputation.
95 explorer 180000 miles have question on 4wd when I turn on the 4wd it will engage and run fine however the light after a short while will blink a few times and then go off and after some more time will blink again a few times then go off but I believe the 4wd is working the whole time any suggestions on what it would be or how to go about to fix the problem would be greatly appreciated<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 09:17 PM
SPONGY CLUTCH? epdukes13 1987 - 1996 F150 & Larger F-Series Trucks 3 07-28-2012 01:33 PM
Tilt Steering Column Problems keithredfirebird 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-30-2010 08:28 AM
Getting Frustrated with 4x4 after hub change... kittyhawksurf 1999 to 2016 Super Duty 33 07-10-2009 04:58 PM
Quits pulling - Fuel pump? avgjoe 1999 - 2003 7.3L Power Stroke Diesel 10 12-29-2004 12:42 AM
Tags
1995, 4wd, 95, 96, drive, engage, explorer, ford, problem, problems, wheel, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
