Carrier Bearing Replacement W/pics.
Old 03-29-2010, 05:12 PM
beanhead6D5's Avatar
beanhead6D5
beanhead6D5 is offline
I had developed a vibration while towing and found that my carrier bearing was going bad.This is what I did to replace it.
I started by marking the driveline with a hammer and punch.This way I would have it in the right position when reassembled.
After I had removed the driveline I remove the nut that holds the carrier bearing in place.
A impact and 1 5/16" socket and prybar did the trick.Make sure you mark witch way the yoke slipes on the splines.
Then the fun begins!I remove the metal housing from the rubber and cut it off with a knive.
With a little help from a cutting torch the bearing was off the shaft.
I warmed the metal guard and it droped right into place with a tap from a hammer.
I set the bearing into place,then used the old bearing to drive it onto the shaft.
I used some thread lock on the nut and thigten the $#@* out of it with my impact.
Then I reassemabled from there.
I also used thread lock on the u-joint bolts also.I don't like drivline bolts coming out.
Not to bad of a job to do.Took about two hours,and no more virbration.
Old 03-29-2010, 05:21 PM
flatbeder's Avatar
flatbeder
flatbeder is offline
Nice job Brad...heck you made that look to easy...
Old 03-29-2010, 05:30 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
For a guy named Beanhead you do great work brother!!!!!
Old 03-29-2010, 05:31 PM
big poppa's Avatar
big poppa
big poppa is offline
Great write with pics Brad. I didn't even know what it looked like in there, disassembled that is, had mine done at the shop. If this one ever goes bad, I'll know how to do it, thanks bro..
Old 03-29-2010, 05:42 PM
hhcobra's Avatar
hhcobra
hhcobra is offline
Great job!!! BTW, Where did beanhead come from?
Old 03-29-2010, 06:10 PM
hucka1a's Avatar
hucka1a
hucka1a is offline
Great work, Brad!
Old 03-29-2010, 06:44 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
Thanks for sharing Brad.. Good to see an actual "how to" Sweet
Old 03-29-2010, 07:02 PM
beanhead6D5
What ya trying to say Jim? JK.
Beanhead came from a old man I use to work with.I wore a green hard hat and he would call me beanhead cause of that %@#$ hard hat.
Thanks guys! I hope this will help someone,and it was easy to do.
Old 03-29-2010, 07:10 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
Great pics and description!! Reps sent.
Old 03-29-2010, 07:17 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Enjoyed your write-up Beanhead even though my short azz truck doesn't have a carrier bearing.
The pics were great.
Now I hope Pete sees this write-up and turns it into a PDF.
You out there Pete? Work your magic.
Old 03-29-2010, 07:21 PM
F350-6's Avatar
F350-6
F350-6 is offline
Great write up.
Hmm. I need to check my impact and sure it has that torque setting.
Old 03-29-2010, 07:46 PM
1999SuperD's Avatar
1999SuperD
1999SuperD is offline
Mine is doing the same thing but mine does it only while starting off.
Old 03-29-2010, 08:05 PM
megawatt00's Avatar
megawatt00
I remember you telling me that story.
Old 03-29-2010, 08:16 PM
Bigcat350's Avatar
Bigcat350
Bigcat350 is offline
Nice job Brad. And as usual great pics with the write up. Reps to you.
Old 03-29-2010, 08:44 PM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
Nice work Brad, reps sent
Quick Reply: Carrier Bearing Replacement W/pics.
