Carrier Bearing Replacement W/pics. - Page 5 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #61
Old 05-13-2013, 11:40 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is gaining momentum as a positive member of FTE.
I just replaced mine tonight. Got the support from O' Reilly's it was a Federal Mogul bearing for about $35 bucks. Fixed the shudder I had at about 45 when it shifted into OD. I thought the converter was going out.
The rubber was shot and its smooth as glass now. Ran it up to 70 with no shakes.
  #62
Old 07-23-2013, 12:20 AM
69cruiser 69cruiser is offline
69cruiser is starting off with a positive reputation.
so im gonna replace my carrier bearing on a 99 f350 cc long bed the one they gave me is E4TZ-4800-Aand dosent look like the F81Z-4800-FA is there a difference
  #63
Old 07-23-2013, 08:43 PM
crop harvester crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
ford dealer sold me p/n e4tz-4800-a, it looked slightly different but worked fine, as in my signature its a short box.
  #64
Old 09-24-2013, 11:40 AM
Lex2002 Lex2002 is offline
Lex2002 is gaining momentum as a positive member of FTE.
All my link changed. EDITOR can you allow me to open for editing???
  #65
Old 11-17-2013, 07:26 PM
monster967 monster967 is offline
monster967 is starting off with a positive reputation.
THREAD RESURECTION!!
I have a 2000 f350 Ext. Cab longbox. I'm in the process of replacing the support bearing. I got the old one off no problem. I'm having issues getting the new one on. I checked the sizes and they are both the same 1.57" i.d. bearings. The new bearing will not slide on easily or even with a few decent taps from a mallet. Any suggestions?
  #66
Old 11-17-2013, 07:46 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Lex, a little late responding to this post, but unlike the thread I'm helping you with, in this case it would be infinitely easier if you just repost your responses above with the correct image links. No need to edit them.
Stewart
  #67
Old 11-18-2013, 01:11 PM
Quote:
Stewart
I will cut and paste in a complete new post with updated picture link. Thanks Stewart.
Lex
  #68
Old 05-02-2014, 06:18 PM
Vijay's Avatar
Vijay Vijay is offline
Vijay is gaining momentum as a positive member of FTE.
Glad, I found this thread. I have one quick question:
Do we need Air tools for this(I mean, must-have versus good-to-have))? Because I do not have any Air tools or compressor!
  #69
Old 05-02-2014, 08:02 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Do you want the answer that you can show your wife?
"Yes! Air tools are necessary! You will never get the job done without them, and you won't be able to save all that money by doing it yourself!"
or the one that gets you nothing new:
"Common hand tools are completely sufficient to accomplish this."
Pop
  #70
Old 05-02-2014, 08:05 PM
Vijay's Avatar
Pop
Thanks!...that will do.
  #71
Old 06-02-2016, 06:47 PM
hbronco96 hbronco96 is offline
hbronco96 is starting off with a positive reputation.
Nice!!
Should have made a video for us "non mechanics"!!!!
  #72
Old 09-30-2016, 06:35 PM
Fuzzpuss Fuzzpuss is online now
Fuzzpuss is starting off with a positive reputation.
Glad I found this thread. I've already greased the slip yolk...without positive results. I also have the vibration upon take-off, either from a dig or a very slow roll. The part number the local dealer gave me based on my vin is F81Z-4800-EA. $101.98 + tax, and that's the whole assembly with the bracket. They also quoted me $48 and change for the shim kit listed above in the TSB, part # EOTZ-4A209A.
  #73
Old 10-04-2016, 11:07 AM
Did you say STEALER or DEALER? My hearing aid is acting up...
Dude...dont do that to yourself. Its bad for your karmic juju. Dealer prices bad bad bad (unless you have a wholesale account).
  #74
Old 10-05-2016, 02:58 AM
I ended-up getting an assembly at Autozone with a Timken bearing for $24. Problem solved.
For future reference, a two-armed gear puller was perfect for pulling the yolk and then the bearing.
It sure is nice when I can identify a problem and get it fixed within a day. If only it could happen more often.
DIY Regulated Return w/fuel bowl delete. beanhead6D5 1999 - 2003 7.3L Power Stroke Diesel 79 02-01-2015 04:06 PM
whats your build? post your pics! powerstroke1979 1973 - 1979 F-100 & Larger F-Series Trucks 34 10-06-2012 11:59 PM
I think the Turbo just died. Sgt93 6.7L Power Stroke Diesel 65 08-09-2012 08:19 AM
My brake booster is hitting my crossmember Doc 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 08-20-2011 09:42 PM
6.0 Intercooler Install beanhead6D5 1999 - 2003 7.3L Power Stroke Diesel 25 06-06-2009 04:46 PM
Tags
03, 2wd, 99, bearing, carrier, diesel, f250, install, installation, metal, pic, powerstroke, precision, replacement, sd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
