Carrier Bearing Replacement W/pics.
Brad, under what conditions were you having the vibration?
The vibration has gone away,but I haven't towed with it yet.I'll let you know tonight what happens.
https://www.ford-trucks.com/forums/8...-take-off.html
https://www.ford-trucks.com/forums/7...-how-much.html
i have a question i just put a new carrier bearing in my dads truck today and i put it together just like in the pictures but the metal clamp has a arrow that suppose to face forward but it faces to the rear axle???? it came out of the box with a metal tap holding the two together can i just cut it off and flip the bracket or did i put it in backwards??
on
I replaced my carrier bearing when I did my trans rebuild not too long ago. I had a torch, but used a different method that those who don't have one might try. I did, however, use a 4'' angle grinder. I removed the hanger bracket and cut the rubber like Brad said. I them use a hammer to crack the outer race and remove the ball bearings and cage. I cut a groove in the inner race with the angle grinder and then split the race with a hammer and large chisel. Be sure and wear eye proection with this method. There may be flying parts!
#29
#30
do you see the bracket in beanheads pic guys? the bracket in the box i got from the dealer does not look like the stock piece, its just a horseshoe and doesnt have the extra lip in the pic facing up. i should just takle a pic of it installed and let yous see what im talking about
Did you get your carrier bearing from a dealer or parts store?
Guys Roland has a good way to remove the bearing or if you can get a three arm puller that would work also.I was a field mechanic for ten years,using the heat wrench is a habbit of mine.
