Carrier Bearing Replacement W/pics. - Page 2 - Ford Truck Enthusiasts Forums
Old 03-29-2010, 10:01 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Quote:
Originally Posted by 1999SuperD View Post
Mine is doing the same thing but mine does it only while starting off.
SuperD,
Here's something you may want to try. LINK Rear drive shaft slip joint lube.
Old 03-30-2010, 05:57 AM
nissandoc's Avatar
nissandoc nissandoc is offline
nissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to all
My brothers 08 does the same thing. Only when towing and only when starting off from a stop. Wonder if this is whats going on? It has less than 30k.
Brad, under what conditions were you having the vibration?
Old 03-30-2010, 06:39 AM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
beanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to all
1800 to 2200rpm when towing very fast vibration.I am picking up some lumber today,and will know for sure if it was the carrier bearing.
The vibration has gone away,but I haven't towed with it yet.I'll let you know tonight what happens.
Old 03-30-2010, 07:43 AM
nissandoc's Avatar
Cool. Thanks Brad.
Old 03-30-2010, 08:38 AM
03_PSD 03_PSD is offline
03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.
Great write-up, mine has a slight vib at highway speeds, now i know how to replace the carrier bearing. Thanks Brad!
Old 03-30-2010, 05:28 PM
brian42's Avatar
brian42 brian42 is online now
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
If yours is only doing it when starting off or from a near standstill, you probably need to grease the slip yoke on the driveshaft like PaysonPSD said...
http://www.ford-trucks.com/forums/81...-take-off.html
http://www.ford-trucks.com/forums/75...-how-much.html
Old 03-30-2010, 07:58 PM
No more vibration when towing! The carrier bearing fixed the prob for me.
Now to grease the slip yoke.Should of done that when it was apart.
Old 03-30-2010, 08:01 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Jees Brad, you didn't do that, you had it all apart
Old 03-30-2010, 09:05 PM
nissandoc's Avatar
Thanks for the update Brad. My Bro is towing a camper down to the Outer Banks tomorrow and we'll see how it does. If it still gives him problems we'll adress it when he gets back.
Old 06-10-2010, 05:25 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
i have a question i just put a new carrier bearing in my dads truck today and i put it together just like in the pictures but the metal clamp has a arrow that suppose to face forward but it faces to the rear axle???? it came out of the box with a metal tap holding the two together can i just cut it off and flip the bracket or did i put it in backwards??
Old 06-10-2010, 05:43 PM
See how the rubber is facing in this pic.Thats how my came off and I put the new one on the same way.Yes I had the metal bracket off,so you could flip it if you have to.
Old 06-10-2010, 05:46 PM
wla6518's Avatar
wla6518 wla6518 is offline
wla6518 is gaining momentum as a positive member of FTE.
Agreed, nice write up. Reps headed your way.
Thanks for taking the time to put that out there!
  #28
Old 06-10-2010, 11:29 PM
mueckster's Avatar
mueckster mueckster is offline
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
I replaced my carrier bearing when I did my trans rebuild not too long ago. I had a torch, but used a different method that those who don't have one might try. I did, however, use a 4'' angle grinder. I removed the hanger bracket and cut the rubber like Brad said. I them use a hammer to crack the outer race and remove the ball bearings and cage. I cut a groove in the inner race with the angle grinder and then split the race with a hammer and large chisel. Be sure and wear eye proection with this method. There may be flying parts!
  #29
Old 06-11-2010, 09:22 AM
do you see the bracket in beanheads pic guys? the bracket in the box i got from the dealer does not look like the stock piece, its just a horseshoe and doesnt have the extra lip in the pic facing up. i should just takle a pic of it installed and let yous see what im talking about
  #30
Old 06-11-2010, 12:22 PM
Quote:
Yes,take a pic and we'll go from there.
Did you get your carrier bearing from a dealer or parts store?
Guys Roland has a good way to remove the bearing or if you can get a three arm puller that would work also.I was a field mechanic for ten years,using the heat wrench is a habbit of mine.
Rear brake caliper thingamabob Doc 2009 - 2014 F150 19 01-28-2017 10:47 AM
Been awhile. still going. eddie21 Explorer, Sport Trac, Mountaineer & Aviator 0 03-14-2015 09:08 PM
She is all packed and ready to go! Sgt93 6.7L Power Stroke Diesel 64 08-01-2011 07:16 AM
Truck is fixed! Sgt93 6.7L Power Stroke Diesel 18 06-14-2011 12:23 PM
Rewiring my 1960 F100 Custom Cab Tumblindyce 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 06-22-2010 09:24 PM
Tags
03, 2wd, 99, bearing, carrier, diesel, f250, install, installation, metal, pic, powerstroke, precision, replacement, sd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
