Electric brake controller for Explorer... - Ford Truck Enthusiasts Forums
Old 03-29-2010, 01:22 PM
dan8052's Avatar
dan8052 dan8052 is offline
dan8052 is starting off with a positive reputation.
I have an '04 Explorer, 4.6l V-8 w/class III receiver from the factory. I have a pop-up trailer (approx. 2800lbs) w/electric brakes. Can someone give me advice as to what brand of brake controller is the best and tips on how to install it? I wasn't sure if Explorers come with any pre-wiring installed from the factory? Any help will be apprciated.
Thanks,
Dan
Old 03-29-2010, 06:06 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
Dan -
A Tekonsha Prodigy will give you the best bang for your $$$; get it with the plug-n-play harness for your Explorer. The under-dash connector is bitchy to find. Drop/remove the glove box and then look behind/up/toward the center; the connector (gray or white, 3-over-3 with 5 wires to it) will be taped up there. You'll still have to run the wiring to the driver's side. Good luck!
Steve
Old 03-30-2010, 10:12 AM
dan8052's Avatar
Is that it? No splicing wires to get power? No running wires to the back of the vehicle? Just plug into the connector and mount the unit somewhere on the drivers side of the vehicle and I'm done?
Old 03-30-2010, 11:40 AM
87mh's Avatar
87mh 87mh is offline
87mh is gaining momentum as a positive member of FTE.
Quote:
There might be a fuse you would have to insert into the fuse block.
Check your owners manual and see if it identifies the trailer fuse item(s).
Check if there is already a fuse installed at that location.
Old 03-30-2010, 04:59 PM
CO River Rat
If you have the tow package (2" receiver with 7-pin RV connector) and nobody's messed with the fuses/breakers required for towing, you're all set. I used a long tie-wrap to pull the harness over to the driver's side.
Steve
Sport Trac electric brake and harness question stephenson Explorer, Sport Trac, Mountaineer & Aviator 2 11-08-2016 07:29 AM
04 Explorer No Heat!!! dan8052 Explorer, Sport Trac, Mountaineer & Aviator 21 11-16-2015 10:51 AM
Electric brakes on Winnebago jaywalkin Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 7 11-07-2011 04:27 AM
Brake controller vs. Trailer brakes dan8052 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 07-28-2010 05:06 PM
brake controller ihclay 1997 - 2003 F150 5 03-10-2009 06:04 PM
Tags
03, 1997, 2003, 2007, 2009, 99, brake, brakes, controller, electric, explorer, ford, install, mount, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
