Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 03-28-2010, 11:55 PM
grockin2004 grockin2004 is offline
Garage is empty, add now
grockin2004 is starting off with a positive reputation.
4WD front Hub and Brake Rotor Removal Help
Can someone help link me to a former thread or a good disassembly guide to properly disassemble the manual locking hub and removing the brake rotor and inspect and pack the wheel bearings?
I am helping a friend with his 78 Ford 4WD. It has been a very long time since I dove into 4WD front ends. The shop manual he has is pretty much useless. So far I have been able to remove the hub lock selector assembly, the big spring, the snap ring and inner axle to hub gear. But now there is a round piece in there that has 4 notches that looks to be on a bearing that I cannot extract from the hole. I cannot tell if there is another snap ring or some other devise keeping it in there. I cannot find information on getting this part out. I figured I'd try asking here before I rig up a gear puller and try removing it with a little pressure.
Is there a special tool needed to get this part out?
Any guidance (particularly with pictures) would greatly appreciated.
  #2 (permalink)
Old 03-29-2010, 12:01 AM
HillbillyDeluxe81 HillbillyDeluxe81 is offline
HillbillyDeluxe81 is starting off with a positive reputation.
That thing with the 4 slots is a giant nut. You need a special socket to remove it.
  #3 (permalink)
Old 03-29-2010, 12:05 AM
fatdan460's Avatar
fatdan460 fatdan460 is offline
1985 american sex machine
fatdan460 has a very good reputation on FTE.fatdan460 has a very good reputation on FTE.fatdan460 has a very good reputation on FTE.fatdan460 has a very good reputation on FTE.
its spindle lock nut. find out if the axle is a dana 44 or dana 60, they both use a seperate size locknut spindle socket or wrench. shouldn't cost much more than 15$ if that
__________________
Quote:
Originally Posted by alpha/omega View Post
His brain wouldnt function under what you would call "normal" conditions. Dan is truely one of a kind. Too weird to live and too rare to die.
your post per day average may be 2.03 but your lols per day far exceed any one else on FTE hands down.
  #4 (permalink)
Old 03-29-2010, 12:14 AM
460/5's Avatar
460/5 460/5 is offline
Zombie Survivalist
460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.
takes the afore mentioned socket. watch out. it SHOULD be cheap, but my 3/4 ton socket cost me almost $50. dunno why, but it did. my 1/2 ton socket only cost $15...
here. i went over this not too long ago. you should find all the info you need here.
http://www.ford-trucks.com/forums/93...g-locknut.html
__________________
Brother Trey- Slackmaster #18
Why I'm called "Brother" Trey- http://www.youtube.com/watch?v=F5h0g...eature=related
'93 Explorer, Eddie Bauer, 4.0, 5 speed (converted), 4x4, 31x10.5 tires.
'84 F250 XL, blue, super cab, long bed w/ 6.9 IDI, T19, 4x4.
  #5 (permalink)
Old 03-29-2010, 12:26 AM
fatdan460's Avatar
geez, crazy. i found a dana 60 one for$20 at orielly's. it was the cheapest one i could find anywhere, but that was probably 5-6 years ago
__________________
Tags
12, 1994, 2000, 4wd, 4x4, brake, f150, f250, ford, front, fwd, hub, lock, removal, remove, rotor, ton, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
