Pressure valve location?
Old 03-28-2010, 11:19 PM
flipklos's Avatar
flipklos
flipklos is offline
Were does one locate the residual pressure vlave in a drum brake setup? Is it before or after the proportioning valve?
Old 03-29-2010, 07:11 AM
bashby's Avatar
bashby
bashby is offline
If used it is part of the combination (Proportionining, metering) valve
Old 03-29-2010, 06:01 PM
flipklos's Avatar
flipklos
flipklos is offline
On the master cylinder side or on the brake side of the proportioning valve?
Old 03-30-2010, 07:11 AM
bashby's Avatar
bashby
bashby is offline
not sure but I think they are only used when the mc is lower than the wheel cyl's
Old 03-30-2010, 11:02 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
It is part of that valve- not before or after. Are you having brake drag issues? A more likely cause is a bad rear brake hose.
Old 03-30-2010, 08:13 PM
flipklos's Avatar
flipklos
flipklos is offline
Intending to install a dual circuit disc conversion on my 64 F100. I realise you only need a residual valve on the discs if the master is lower. On drum brakes however you need to utalize a 10 psi valve to prevent air infiltration and brake drag. I know you need one as my 85 has an aftermarket proportioning valve due to my original going out. I suffer bleed back in the drums and one has to pump them several times to restore the drums to use.
I am simply curious to which side of the proportioning vlave one mounts the residual valve.
Shanemh
02-28-2016 02:59 PM
Flat Boosted
1999 to 2016 Super Duty
02-20-2013 12:12 AM
01stroker
07-27-2004 08:22 AM
fossl
1997-2006 Expedition & Navigator
07-11-2004 07:52 AM
u130747
12-09-2003 11:40 AM
Quick Reply: Pressure valve location?
