Pressure valve location? - Ford Truck Enthusiasts Forums
Old 03-29-2010, 12:19 AM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
Were does one locate the residual pressure vlave in a drum brake setup? Is it before or after the proportioning valve?
Old 03-29-2010, 08:11 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
If used it is part of the combination (Proportionining, metering) valve
Old 03-29-2010, 07:01 PM
On the master cylinder side or on the brake side of the proportioning valve?
Old 03-30-2010, 08:11 AM
bashby's Avatar
not sure but I think they are only used when the mc is lower than the wheel cyl's
Old 03-30-2010, 12:02 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Quote:
It is part of that valve- not before or after. Are you having brake drag issues? A more likely cause is a bad rear brake hose.
Old 03-30-2010, 09:13 PM
Intending to install a dual circuit disc conversion on my 64 F100. I realise you only need a residual valve on the discs if the master is lower. On drum brakes however you need to utalize a 10 psi valve to prevent air infiltration and brake drag. I know you need one as my 85 has an aftermarket proportioning valve due to my original going out. I suffer bleed back in the drums and one has to pump them several times to restore the drums to use.
I am simply curious to which side of the proportioning vlave one mounts the residual valve.
High pressure oil check valve location brickie 6.0L Power Stroke Diesel 1 12-06-2007 12:38 AM
Check valve and fuel pressure regulator submakr 1997-2006 Expedition & Navigator 0 12-18-2005 01:51 PM
Fuel Schrader Valve Location 01stroker 1999 - 2003 7.3L Power Stroke Diesel 11 07-27-2004 09:22 AM
Valve location beckyhaynes Cooling, Heating, Ventilation & A/C 2 07-25-2004 03:25 PM
1979 Ford Air Conditioning benniebob Cooling, Heating, Ventilation & A/C 1 05-10-2004 08:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
