Can I tow it?
Can I tow it?
Hey everybody! I have a 2010 Ford F150 Supercrew 4x4 Lariat with the 5.4 liter and the 3.73 tran. also with the Maxtow package. I am looking at buying a 35 foot travel trailer that weights 8000 pounds. It has 1000 lbs hitch weight. You figure I will pack another 1200 in there when we go camping. I plan on getting the transmission cooler. Can I tow that trailer?
I think you can find the answer here; 2010 Ford F-150 Towing Capacity | The Official Site of the 2010 Ford F-150 | FordVehicles.com
It looks like you can pull up to 9500# (157"WB)or 9600# (145"WB) and be within factory allowances.
PS I forgot about the "Maxtow" package, Fordtruckman is right.
The maxtow should have included a cooler. But definitely get a transmission temperature gauge.
This question also depends on where you are and where you want to tow to. For a fairly heavy trailer like that towing on flat ground shouldn't be a big issue especially at anywhere close to sea level, but if you get into high country with long grades and higher elevations you might find the truck a bit taxed with that much weight on. Remember that a naturally aspirated engine will lose 3% of its output for every 1,000 feet of elevation you gain.
You should certainly obtain a weight distribution hitch preferably one with sway control.
See here for examples; Weight Distribution WD With Sway Control | etrailer.com
Lots of advice available in the towing forum of FTE; Towing, Trailers & 5th Wheels - Ford Truck Enthusiasts Forums
They do and they don't... It's more like an idiot light in gauge form. They go to "regular operating temp" position until the trans is really cooking. Then it will shoot over to overheating. It doesn't show temps gradually increasing like a real gauge. An aftermarket gauge would be a good idea when towing something so close to max the vehicle's limit. I don't think another trans cooler is needed though. The max tow cooler looks pretty substantial.
when i traded my 06 f350 for my 09 f150 it was ok at the time. a few things changed in life and i was towing more. when i was only towing once in a while with it I was satisfied, now that im towing more often and further i cant stand the truck any more and will be going back to a diesel this year.
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
02-17-2017 01:08 PM
AKHunter93
27
05-09-2016 04:42 AM
RedRaiderFan
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
09-13-2015 09:18 PM
