S. California Chapter Join Chapter, Leader:
I NEED HELP THIS PROBLEM IS STOPING ME
Old 03-28-2010, 02:30 PM
70underconstruction's Avatar
70underconstruction
70underconstruction is offline
MY SHIFTER IS RELLY LOOSE CAN ANYONE TELL ME HOW THIS PART WORKS OR HOW IN THE WORLD DO I FIX IT I CANT GET IT OUT OF DRIVE
Old 03-28-2010, 03:34 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Pretty sure you'll have to replace the whole mechanism...that's what I had to do on my '76 when I had that same problem. It's been so long since I've done it that I don't think I can walk you through, but I'm sure someone in the 67-72 forum can help you out.
Here's a link: 1967 - 1972 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old 04-02-2010, 06:59 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
^ ^ You don't have to replace the whole mechanism, Steve. All the OP needs is a new shift collar. The pic shows it's broken internally. ^ ^
Originally Posted by 70underconstruction
MY SHIFTER IS REALLY LOOSE CAN ANYONE TELL ME HOW THIS PART WORKS OR HOW IN THE WORLD DO I FIX IT I CANT GET IT OUT OF DRIVE
Welcome to FTE & the SoCal Chapter
The shift collar that the shift lever fits into is broken internally, which is very common problem. The collar is available from Ford.
D5TZ7228A (replaced C5TZ7228B & C9TZ7228A) .. Shift Collar Kit / Fits: 1965/77 F100/350 with A/T.
MSRP: $65.98 // FTE sponsor PARTSGUYED.COM price: $47.51.
PARTSGUYED = Horizon Ford in Seattle (Tukwila) WA.
btw: The only Ford dealer locally that has one in stock is Galpin Motors on Roscoe Blvd. in Van Nuys. But you won't get the FTE discount price from them.
Old 04-02-2010, 09:31 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Bill, you are F'n AMAZING!
Of course, to you, this is just routine stuff......
Impressive, just the same, to a layman.
Pop
Old 04-02-2010, 09:21 PM
AlexC's Avatar
AlexC
AlexC is offline
The shifter on my truck is a bit loose and it the indicator and the gear display plate do not quite line up (need to move the shifter halfway to the gear). Could this be a similar issue?
Old 04-03-2010, 02:27 AM
NumberDummy
I doubt it.
When the collar breaks (on an A/T), you're stuck in whatever position the shift lever is in.
More than likely, the upper and lower steering column bearings are worn, ([2] C3DZ3517A-available from Ford), plus...on the manual control selector on the steering column under the hood is a rubber bushing and insulator. When the bushing ages, it cracks apart causing slop in the lever.
The bushing and insulator came as a kit (C5TZ7343A). Ford just obsoleted this kit, but there are 100's available at dealers, obsolete parts vendors.
ufvj217
1999 to 2016 Super Duty
09-04-2015 08:40 AM
dadlovesfords
1997 - 2003 F150
12-02-2014 03:02 PM
F100Trucker
21
12-28-2013 02:03 PM
flavo
13
03-28-2013 07:25 AM
canadianfordguy
10-25-2009 10:32 PM
Quick Reply: I NEED HELP THIS PROBLEM IS STOPING ME
