Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 03-28-2010, 12:43 PM
ford_0004 ford_0004 is offline
Garage is empty, add now
ford_0004 is starting off with a positive reputation.
78 300 I6 perchs/mounts
Would like to have a set or engine perches and motor mount for a 78' f150 ?
I live near Newark,Oh
  #2 (permalink)
Old 03-30-2010, 08:15 PM
fordman75 fordman75 is offline
1996 Ford E250
My Garage
fordman75 has a good reputation on FTE.fordman75 has a good reputation on FTE.
2wd or 4wd?
__________________
Ted
1954 F100 4x4, 300, NP435/NP205
  #3 (permalink)
Old 03-30-2010, 08:23 PM
4wd . someone torched mine out .
  #4 (permalink)
Old 04-05-2010, 01:02 PM
1996 Ford E250
My Garage
Quote:
I might have a pair that will work for you. They are out of a 70's 4x4 with a 300 but I'll need a couple measurements off your frame to make sure they are the correct ones for your truck.
Your original ones should have had two bolts going thru the top of the frame on each side. I need the measurements from the center of those bolt holes to the inside edge of the frame for each side.
If you can get those measurements I'll check and make sure these will fit your truck.
__________________
Ted
Tags
300, ford, frame, mounts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
