New Fuel Filter for the 6.0 from Ford? Motorcraft FD-4616 - Ford Truck Enthusiasts Forums
Old 03-28-2010, 10:35 AM
hank89 hank89 is offline
hank89 is starting off with a positive reputation.
Does anyone know if Ford has come out with new fuel filters for the 6.0? I went to my local Ford dealership on Friday to purchase a set and the guy behind the counter handed me Motorcraft FD-4616. After looking for the filter for about 5 minutes he said it looked like Ford had changed the part number and increased the list price to $99.
When I went to put in on today I noticed that the main filter was different than the one I was taking off. The inner part of the filter that you push into the housing has a rubber gasket on it while the filter I replaced does not have one. The first thing I thought was that he gave me a filter for the 6.4. When I put the filter on it the plastic cover did not seat to the housing. I guess there is about a 3/16" gap. I figured it would leak, but it did not. When I got home and checked a filter online site the 6.4 product number is FD-4617.
I'm sitting here looking at the box and it says Motorcraft FD-4616 and I can not find anything on the internet regarding this filter.
Thanks,
Hank.
Old 03-28-2010, 10:40 AM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Correction.
Fuel filter is $50 from dieselfiltersonline.com
http://www.dieselfiltersonline.com/F...s-Fd-4606.aspx
The new one is not listed yet... but it should be about the same.
Motorcraft list it here:
Part Name: Fuel Filter
Manufactured By: Motorcraft
Part Description:
Part Number: FD-4616
Price: $99.98
Immediate question: what application that you have that you cannot use the cheaper one?
Part Name: FILTER ASY - FUEL
Part Description:
Part Number: FG-1095
Price: $89.98
I would email / call Dieselfiltersonline.com and see how much is their "updated" filter cost.
Bet you it will be $50.
Old 03-28-2010, 10:46 AM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
If you go to this page bismic has posted a picture of the new fuel filter for the 6.0
Ford Truck Enthusiasts Forums - bismic's Album: New Fuel Filter - Picture
I agree with gearloose1 I also buy from diesel filters online but I purchase the Racor Filter 34.89 who makes the filters for motorcraft
http://www.dieselfiltersonline.com/P...-Pff-4604.aspx
Old 03-28-2010, 11:26 AM
Quote:
Originally Posted by gearloose1 View Post
Correction.
Are you saying that Ford has two fuel filters available now depending on your application?
There must be a reason they have switched filters. There is a big difference between the two. Note the inner gasket on the new one. Maybe the old one didn't do a good job of filtering. I don't know.
But, I have always bought my filters from the dealership. I did not know I could get them for 40 bucks elsewhere. I will make a note of it and buy elsewhere next time. The previous filter cost me $62 at the dealership and the new one cost $72
Old 03-28-2010, 11:30 AM
Old 03-28-2010, 11:51 AM
Hank
Key point: most dealers will negotiate over price at the parts counter...
20% parts and labor discount is not uncommon.
Old 03-28-2010, 03:16 PM
RickF350's Avatar
RickF350 RickF350 is offline
RickF350 is gaining momentum as a positive member of FTE.
What is wrong with the old filters?
Anyways, International dealers also sell filters cheaper than Ford. # 1847170c92 or 1847170c93
Old 03-28-2010, 03:22 PM
My international dealer is closer and cheaper than Ford all the time.
Old 03-28-2010, 04:38 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I believe the new filter will be International part number 1847170c94.
The old filter would allow some "bypassing" when the pressure drop through the filter got large. The new filter will not allow that - it will continue to restrict the flow instead.
I guess folks were experiencing some water getting to the injectors when they got really bad fuel. The primary filter would "bypass" and the secondary filter was not (and is not) designed or intended to "block" the water.
Old 03-28-2010, 04:43 PM
Randy777 Randy777 is offline
Randy777 is starting off with a positive reputation.
It appears the new filter will cost more. But is it a better filter? If not everyone will probably be stocking up on the old one. I hope we find out soon as I will be buying a few extras.
Old 03-28-2010, 04:47 PM
Wow, as usual Bismic answers my question before I can type it out. Bismic you must be Psychic.
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.
Kind of like "pick your poison." Go with the filter that won't allow a little bypass under certain circumstances and risk a pressure drop that may damage your injectors or go with the filter that does allow a little bypass under certain circumstances but risk a little water reaching your injectors that can also lead to damage. Can't win for losing it seems.
Old 03-28-2010, 04:50 PM
Quote:
I would assume the old filter will go out of production and eventually only the new filter will be available.
Old 03-28-2010, 04:53 PM
bismic's Avatar
I think Ford went the right direction on this Frank. The worst situation would be the water bypass. I just get amazed though at what we have to "discover" when it comes to maintaining our trucks (two examples are the fuel pressure that you mentioned and the other is the EOTvsECT temperature difference).
Old 03-28-2010, 05:15 PM
Good point Mark. I think it's also important that we all should be draining the water separator on a regular basis. This will reduce the risk of bypassing water when using the old filter. The manual says to do this task monthly. I followed this schedule religiously for the first four years. But after finding only a couple or so very small drops occasionally, I've gone to every other month unless I'm on the road and fuel at a spot that is unfamiliar to me. Of course this won't help if you get a bad load of fuel, but it will help elimate the slow build up of water that occurs over time with repeated fuel ups. I read where some guys only drain theirs every oil change or so and cringe. This is like playing russian roulette with your injectors. Every little bit we can do to help ourselves goes a long way and is like money in the bank.
I still have a set of the old filters in my stash but I guess I will be restocking with the new filter when the time comes.
06 F350 DRW Maintenance Part Numbers psi4pwr91 1999 to 2016 Super Duty 2 12-24-2015 07:37 AM
Motorcraft FD4616 fuel filters mxer0022 Ford Truck Parts for Sale 1 05-25-2015 09:28 PM
Upgraded FD 4604 to FD 4616 ? Per4mance 6.0L Power Stroke Diesel 1 09-14-2013 05:19 PM
Diesel filters online.com cefloyd 6.0L Power Stroke Diesel 17 07-08-2012 05:06 PM
4616 vs 4604 fuel filter install danocross 6.0L Power Stroke Diesel 19 12-10-2010 04:20 PM
Tags
60, diesel, difference, fd4604, fd4616, fd4617, filter, filters, ford, fuel, kit, motorcraft, powerstroke, psd, updated
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
