Engine cuts out when wipers turn on. 7.3 Powerstroke
2000 F350. Just installed new CPS, IPC, Fuel filter.
The truck didnt want to run in the rain so I thought it was a water issue. While driving yesterday I noticed that the engine would cut out when the wipers went on. Not every time, just on ocasion. Check engine light would come on some of the time when engine cuts out.
I do not have code reader.
Please help.
Please help.
The following users liked this post:
Where did you get your CPS? This seems to be a common issue with the aftermarket CPS. The wipers create some electrical interference that get's in the way of the aftermarket CPS signal.
If the CPS is from Ford or International, unplug it and make sure the little rubber seal is still on the plug. Maybe even try coating the rubber seal with some di-electric grease to keep it sealed up.
Same Issue!
I'm having the same issue with my truck. Every time I turn my wipers on, rain or shine, it stalls my engine. I also get the check engine light. I have tried to replace my wiper motor, which was not the issue. I have replaced my CPS 3 times, with aftermarket parts. I will pick one up from Ford today. However, does anyone have any other suggestions?
Read. Follow instructions.
Replace CPS with FORD CPS.
^ WHS
