Engine cuts out when wipers turn on. 7.3 Powerstroke - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-28-2010, 10:58 AM
StevieMc's Avatar
StevieMc StevieMc is offline
StevieMc is starting off with a positive reputation.
2000 F350. Just installed new CPS, IPC, Fuel filter.
The truck didnt want to run in the rain so I thought it was a water issue. While driving yesterday I noticed that the engine would cut out when the wipers went on. Not every time, just on ocasion. Check engine light would come on some of the time when engine cuts out.
I do not have code reader.
Please help.
Old 03-28-2010, 01:02 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Where did you get your CPS? This seems to be a common issue with the aftermarket CPS. The wipers create some electrical interference that get's in the way of the aftermarket CPS signal.
If the CPS is from Ford or International, unplug it and make sure the little rubber seal is still on the plug. Maybe even try coating the rubber seal with some di-electric grease to keep it sealed up.
Old 03-28-2010, 01:12 PM
StevieMc's Avatar
The CPS is from Orielly. I dont remember what brand exactly.
I will take the truck into Ford to have Ford brand CPS installed for the recall.
Hope that helps.
Thank you
Old 03-28-2010, 01:30 PM
F350-6's Avatar
I'm guessing it will fix your problem. Be sure to come back and let us know.
Old 03-28-2010, 01:54 PM
fifthwheel01 fifthwheel01 is offline
fifthwheel01 is starting off with a positive reputation.
Replace the CPS, I had the same problem, solved it with a new CPS
Make sure to put your old ford Cps back in before you take it in, I don't believe they will put in a new one if they dont take out the old (ford) one out.
Old 03-29-2010, 05:09 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
Make sure there isn't water getting to the backside of your fuse panel under the dash. Sounds like the typical water issue with leaking windshields. Especially since it happens when you turn your wipers on and its raining.
Old 03-29-2010, 07:59 PM
12ozd's Avatar
12ozd 12ozd is offline
12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold
x3 on CPS !
Old 03-30-2010, 09:54 PM
StevieMc's Avatar
I had Ford replace my aftermarket CPS today with a Ford unit.
Drove home about 50 miles with wipers on intermittent, no cut outs. It was not raining. I had the wipers on just to test.
So far the Ford CPS seemed to fix the problem....this forum rocks!!!!
Old 09-11-2013, 10:50 AM
Jumprgrl367's Avatar
Jumprgrl367 Jumprgrl367 is offline
Jumprgrl367 is starting off with a positive reputation.
Same Issue!
I'm having the same issue with my truck. Every time I turn my wipers on, rain or shine, it stalls my engine. I also get the check engine light. I have tried to replace my wiper motor, which was not the issue. I have replaced my CPS 3 times, with aftermarket parts. I will pick one up from Ford today. However, does anyone have any other suggestions?
Old 09-11-2013, 12:14 PM
ToMang07's Avatar
ToMang07 ToMang07 is online now
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Quote:
Yes.
Read. Follow instructions.
Replace CPS with FORD CPS.
Old 09-11-2013, 01:23 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
As mentioned above, wipers causing a cut out or stall is 99.99% of the time the result of an aftermarket CPS. Replace with Ford OEM.
Quote:
Originally Posted by ToMang07 View Post
Yes.
^ WHS
Old 09-11-2013, 01:29 PM
Thanks... No need to be ignorant!
Old 09-11-2013, 01:37 PM
ToMang07's Avatar
Nor is there need for redundant questions, but alas, here we are.
Old 09-11-2013, 03:08 PM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is offline
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
I bet it was a BWD cps. It does the exact same thing on my truck. The BWD cps makes my truck idol smoother, but, when it dies from turning on the wipers it's not so great anymore!
Old 09-11-2013, 03:16 PM
A/Ox4's Avatar
9 ECHO 1
Quote:
My BWD is a rare one. It smooths out the idle AND works in the rain
No intermittent wipers- wipers will not park after using washer?? No cost fix!! phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 50 11-18-2016 11:22 PM
2001 Expedition Rear Wiper, bad switch??? Tparkin99 Electrical Systems/Wiring 1 07-04-2014 04:00 PM
Engine cuts out with wipers chrissknr 1999 - 2003 7.3L Power Stroke Diesel 28 04-26-2013 03:30 PM
intermittant wiper causes engine stumble karnett 1999 - 2003 7.3L Power Stroke Diesel 9 06-15-2006 04:03 PM
engine stumbles or cuts out karnett 1999 - 2003 7.3L Power Stroke Diesel 6 05-31-2006 03:17 AM
Tags
2000, 73, aftermarket, cam, cps, cuts, cutting, diesel, f250, ford, motor, position, powerstroke, sensor, slow, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
