Engine cuts out when wipers turn on. 7.3 Powerstroke - Page 2 - Ford Truck Enthusiasts Forums
Old 09-11-2013, 04:11 PM
tappit01's Avatar
tappit01 tappit01 is offline
tappit01 has a good reputation on FTE.tappit01 has a good reputation on FTE.
just wonder here but, could you change the ground location on the wipers to clear up this problem?
Old 09-11-2013, 04:14 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Quote:
Yes.
But why not just get the correct part. Its about $20.
Old 09-11-2013, 04:18 PM
tappit01's Avatar
Quote:
Originally Posted by A/Ox4 View Post
Yes.
i would buy the correct one, but the guy who didn't might have a bunch of wire laying around in his garage.
Old 09-11-2013, 04:25 PM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is offline
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
I have been thinking of replacing my wiper motor to try to solve the problem. I believe the motor may have an issue and mabe why the cps kills the truck. I have in the past years seen a wiper motor code come up on my AE once or twice. The codes came up long before trying the BWD cps. So mabe us that are having the issue with the BWD have a worn out wiper motor causing interference????
Old 09-11-2013, 04:32 PM
tappit01's Avatar
Quote:
i no the grounds seem to be a problem at times, it worth a shot.
i no this dont compare but...
i had a 94 dodge dakota once that i bought cheap because the guy said it had an electrical problem and the wipers would'nt work even with a new motor in place. i ran a new ground wire and never had a problem again.
Old 11-07-2013, 07:12 AM
Tact's Avatar
Tact Tact is offline
Tact is gaining momentum as a positive member of FTE.
What code(s) are showing up when the CEL light comes on?
I had a similar situation yesterday in the rain and I recently replaced my CPS with an aftermarket CPS from Autozone. I think it was a Duralast brand.
I changed it trying to fix another issue which ended up being a bad ICP, but I kept the original CPS as a spare.
My symptom was while my truck was shifting gears it would stumble for a split second. At one point the CEL came on and I intend to pull the Code(s) sometime this morning. Curious as to what code(s) I need to be looking for to see if my CPS is the issue.
Old 08-12-2014, 05:26 PM
Oregon Oregon is offline
Oregon is starting off with a positive reputation.
Unhappy wipers shutting down engine
I am have having this same problem with my 1999 7.3 super duty. Using the wipers will shut down the engine. It happens rain or shine. Replaced the cps with a ford cps. Still happening. Replace the wiper motor, still happening. Re wired the wiper motor, still happening. I had a mechanic spend two days going over all the wiring ect. He has no idea. If I am giving the truck fuel it just hiccups and the check engine light comes on. If I am at a stop engine shuts off. Please help with any advice!!!! I have tried everything and have reached a point I may have to sell.
Old 08-12-2014, 06:30 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Checked all your ground connections? A bad ground in the electrical system can cause the wipers to trip the stall issue.
Old 08-12-2014, 06:39 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
I've read where people have solved that problem by relocating the wiper ground elsewhere. I can't speak from experience on this issue, though.
Old 08-12-2014, 08:06 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Quote:
Originally Posted by StevieMc View Post
I had Ford replace my aftermarket CPS today with a Ford unit.
Drove home about 50 miles with wipers on intermittent, no cut outs. It was not raining. I had the wipers on just to test.
So far the Ford CPS seemed to fix the problem....this forum rocks!!!!
Yea, But now you have a scratched windshield.......LOL
Old 08-12-2014, 11:16 PM
Checked all grounds and hard wired the wiper motor to isolate the motor. Problem still occurs.
Old 08-13-2014, 01:08 AM
Y2KW57's Avatar
Y2KW57 Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
Oregon... try turning on your wipers very quickly past all the intermittent settings directly to full on fast wiping. Does it still stall? Most people report that the stalling only occurs when the wipers are turned to an intermittent setting. If we determine that is the case with yours too, then we can at least know that the failure you are experiencing is similar to most people who have had the same problem.
If you find that the truck no longer stalls when turning the wiper switch quickly and immediately past any intermittent setting... all the way to full run, then at least you have a temporary work around to fall back on, since it does rain quite a bit in Oregon.
  #28
Old 08-24-2014, 08:37 PM
You are right it has not stalled so far if I go quickly to the fast speed. Yet, stalls as I go through the intermittent speeds. So at least I can drive in the rain for now. Trouble shooting continues
  #29
Old 08-25-2014, 07:12 AM
Y2KW57's Avatar
Quote:
Great, we've made some critical progress then!
You don't have to sell it, and you can still drive it. (Because it always is raining in Oregon!). Also, to be clear, you don't have to have your wipers in the "FAST" position all the time... you just have to turn your wipers on QUICKLY, rotating the switch PAST all of the interval settings. You can still run your wipers on the SLOW speed, as long as it is slow in the steady state position, not slow in the interval position.
What we are trying to avoid here (until the issue gets resolved permanently) is allowing the wiper switch to linger momentarily in any Interval position, as that will stall the truck. So I would suggest rotating the wiper switch quickly to FAST, then back it down one notch to Slow. This at least gives you two speed wiper operation.
The progress in diagnosis has pointed toward potential involvement with the General Electronic Module (GEM module).
Ford's workshop manual states: "When the wiper switch is placed in the interval wipe positions, the GEM responds to the windshield wiper washer switch commands."
I'm not suggesting running out and replacing your GEM. Replacing a GEM the way Ford recommends involves reprogramming the module, which generally is done with a factory scantool (not AE) that supports flash programmable module configuration capture (aka PMI extraction) and reprogramming.
One thing that would help in continuing the diagnosis is to scan the truck (with a Ford specific scantool capable of retrieving Body, Chassis, and ABS codes) to look for any resident DTC body codes from the GEM module, like B1342, B1450, B1453, etc.
This may sound weird, but for the sake of eliminating one tangent of issues with the GEM module early on, make sure all of your brake lights work... in both tails and in the CHMSL, if you have one (3rd brake light at back of cab).
I think the next step would be getting a genuine scan tool and looking for any resident Body codes from the GEM. That tool should be also capable of running a multifunction switch test.
  #30
Old 08-25-2014, 07:23 PM
landmobile's Avatar
landmobile landmobile is offline
landmobile has a good reputation on FTE.landmobile has a good reputation on FTE.landmobile has a good reputation on FTE.
Beautiful troubleshooting!
No intermittent wipers- wipers will not park after using washer?? No cost fix!! phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 50 11-18-2016 10:22 PM
Any 53-56 F100 owners answer this wiper motor question? Bluey Zedoff Australia Chapter 0 11-05-2014 01:42 PM
2001 Expedition Rear Wiper, bad switch??? Tparkin99 Electrical Systems/Wiring 1 07-04-2014 03:00 PM
01 Exp, Possible bad rear wiper switch??? Tparkin99 1997-2006 Expedition & Navigator 0 07-04-2014 02:54 PM
Engine cuts out with wipers chrissknr 1999 - 2003 7.3L Power Stroke Diesel 28 04-26-2013 02:30 PM
Tags
2000, 73, aftermarket, cam, cps, cuts, cutting, diesel, f250, ford, motor, position, powerstroke, sensor, slow, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
