09 Flex-part fell out
What is it??
A small plasticpiece fell out of the bottomof the engine compartment when I slammed the door.
Looks like some sort of relay holder
the following numbers are stamped on it;
AE93-8A194-AA
PA-GF33
BFPUK
CAV 6
Any ideas? I'm 400 miles from home at the moment.
Thanks
psajunk
AE93-8A194-AA
PA-GF33
BFPUK
CAV 6
Thanks
psajunk
What is it??
AE93-8A194-AA
PA-GF33
BFPUK
CAV 6
Thanks
psajunk
AE93-8A194-AA
PA-GF33
BFPUK
CAV 6
Thanks
psajunk
I'd say the best you could do is check all your fuseboxes and relay boxes (got your owner's manual? If not go to fleetford.com) to make sure everything is still there and if it is, assume that someone at the factory left you an extra part...
Weird,
George
That is the clamp that holds the top of the radiator in, there are two, one each side on the top. The two little tabs stick through the "G.O.R." or radiator frame. You might be fine without it, or, your radiator may jump around enough to cause an issue. I've been living with only one for years.
mod22
05-10-2018 04:22 PM
Onus
04-11-2010 03:03 PM
