2002 Explorer erratic fuel gauge Please Help!!!!
Old 03-27-2010, 09:35 PM
WiNgRg's Avatar
WiNgRg
WiNgRg is offline
Hi, my wife 2002 Explorer start to give me a lot of problems, last week we fill the fuel tank completly, next day start with erratic readings needle goes down and up, sometimes read empty sometimes half tank, i dont know where to start to verify if someone can direct me going to be apreciate. TX
Old 03-29-2010, 08:15 AM
marragtop's Avatar
marragtop
marragtop is offline
Sounds like the float in the tank is bad which would require dropping the tank and replacing the unit. I suppose it could be the gauge itself, but the sporatic reading problem you describe usually means the float.
Old 03-29-2010, 09:07 AM
WiNgRg's Avatar
WiNgRg
WiNgRg is offline
OMG, can you tell me where i can find a guide how to take down the tank or any idea if i have to buy the complete unit or i can buy the float separetly,TX.
Old 03-29-2010, 09:56 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
Before dropping the tank, I would check the tank electrical ground and gauge wire for continuity.
Old 03-29-2010, 06:10 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
if it moves up and down randomly, its more often a loose or broken wire than the float/ switch.
Old 03-29-2010, 10:57 PM
WiNgRg's Avatar
WiNgRg
WiNgRg is offline
TX for the advice guys i going to verify on the weekend, for loose cables or connectors prior to take down the tank and post results as always TX for the advice.
Old 04-06-2010, 01:08 AM
wwace's Avatar
wwace
wwace is offline
All my fuel guages read erratically when i park on inclines, off by as much as 3/8 tank reading. Are you on level ground?
whisler
64
02-06-2017 04:51 PM
Boofracinginc
06-17-2016 03:39 PM
j1msevier
10-17-2015 07:22 AM
ericcumbee
08-17-2012 09:49 PM
teamshadyinc
10-05-2010 11:37 AM
Quick Reply: 2002 Explorer erratic fuel gauge Please Help!!!!
