2002 Explorer erratic fuel gauge Please Help!!!! - Ford Truck Enthusiasts Forums
Old 03-27-2010, 09:35 PM
WiNgRg WiNgRg is offline
WiNgRg is starting off with a positive reputation.
Hi, my wife 2002 Explorer start to give me a lot of problems, last week we fill the fuel tank completly, next day start with erratic readings needle goes down and up, sometimes read empty sometimes half tank, i dont know where to start to verify if someone can direct me going to be apreciate. TX
Old 03-29-2010, 08:15 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Sounds like the float in the tank is bad which would require dropping the tank and replacing the unit. I suppose it could be the gauge itself, but the sporatic reading problem you describe usually means the float.
Old 03-29-2010, 09:07 AM
OMG, can you tell me where i can find a guide how to take down the tank or any idea if i have to buy the complete unit or i can buy the float separetly,TX.
Old 03-29-2010, 09:56 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Quote:
Before dropping the tank, I would check the tank electrical ground and gauge wire for continuity.
Old 03-29-2010, 06:10 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
if it moves up and down randomly, its more often a loose or broken wire than the float/ switch.
Old 03-29-2010, 10:57 PM
TX for the advice guys i going to verify on the weekend, for loose cables or connectors prior to take down the tank and post results as always TX for the advice.
Old 04-06-2010, 01:08 AM
wwace wwace is offline
wwace is starting off with a positive reputation.
All my fuel guages read erratically when i park on inclines, off by as much as 3/8 tank reading. Are you on level ground?
Erratic Fuel gauge gimmeagig 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 04-17-2014 03:17 PM
02 Sport Trac Fuel Gauge stopped working ericcumbee Explorer, Sport Trac, Mountaineer & Aviator 2 08-17-2012 09:49 PM
Intermittent rough idle on 96 F150 teamshadyinc 1987 - 1996 F150 & Larger F-Series Trucks 5 10-05-2010 11:37 AM
Erratic Fuel Gauge lymo Explorer, Sport Trac, Mountaineer & Aviator 4 12-07-2003 01:35 PM
90 F150 Fuel Problem mawatson Ford Inline Six, 200, 250, 4.9L / 300 2 07-28-2003 04:14 PM
Tags
1994, 2002, empty, explorer, ford, fual, fuel, full, gage, gauge, problem, shows, sport, trac, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
