South Carolina Chapter Join Chapter, Leader: SC_Hoaty
SC Archived Buy/Sell/Trade Ads
Old 09-05-2006, 11:35 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Arrow SC Archived Buy/Sell/Trade Ads
Chapter Buy/Sell/Trade Ads: Each chapter will have one (1) thread for chapter members to list items wanted, for sale or for trade. The rules for posting in this thread are as follows:
  • Only Ford truck related items and automotive tools & equipment can be listed.
  • Only one picture is allowed per post, per item. If additonal pictures are necessary, place a link in your post to those pictures. Additional posted pictures will be removed without warning.
  • You must have your private messaging (PM) turned on and be able to receive PM's to post an ad in the Chapter thread. If you do not, your post will be removed.
  • Use the PM or email system to conduct all discussion and transactions regarding the item(s). You can post your interest in the item(s) and that you’ll contact the seller but no discussions. Keep it short.
  • If you post an ad, please reply that you found, sold or otherwise disposed of the item.
  • The buy/sell/trade thread will be purged periodically for old postings. Generally every 30 to 60 days.
  • You need to be an active Chapter Member on FTE to post a wanted, for sale or for trade item(s). No Exceptions.
  • You must have permission from the Chapter Leader or a Regional Moderator to post an ad in a chapter that you are not a member of.
  • If you are new to FTE (less than 15 days) or have less than 25 posts, you must contact the Chapter Leader for permission before posting an ad.
  • Your ad or reply to any ad is subject to editing or deletion at discretion of the Chapter Leader, Moderators or Administrators of FTE.
  • Commercial advertisements are strictly prohibited.
Archived SC Buy/Sell/Trade Ads: https://www.ford-trucks.com/forums/7...trade-ads.html
Old 04-06-2008, 12:53 PM
SC_Dave's Avatar
SC_Dave
SC_Dave is offline
Truck Bed Tool Box F/S
[IMG]<a href="http://s282.photobucket.com/albums/kk247/SC_Dave/?action=view&current=WeatherGard336-3.jpg" target="_blank"><img src="http://i282.photobucket.com/albums/kk247/SC_Dave/WeatherGard336-3.jpg" border="0" alt="Photobucket"></a>[/IMG]
This box is about 5 years old but has never been in the weather always under a bed cover. New it sells for $600.00 - $700.00. It works well I just don't need it anymore. I'll take $300.00. Pick up only. I'm in Florence. PM me if interested.
David
Old 04-06-2008, 01:04 PM
SC_Dave's Avatar
SC_Dave
SC_Dave is offline
Stock filter housing, tunnel, tray, battery cover
Installed AIS on my 02 7.3 so this stuff has been removed. Nothing wrong with it. It also has the filter minder and temp sensor with it. Best offer. PM me.
David
Old 04-15-2008, 06:27 AM
STGFordCrazy04's Avatar
STGFordCrazy04
STGFordCrazy04 is offline
Harry,
dont ask me why but every time I try to PM you my computer locks up so Ill try it this way.
Up until about 3-4 weeks ago I had a real good C4 for a 289 302 351W bolt pattern (youve got luck like me) but Ive still got the yoke and flexplate but I dont have the torque converter.
I also have a FMX trans that Im sure would need a full rebuild but I cant remember what it came behind. I think a FE so that wouldnt work.
I honestly dont know what, if anything, will swap between the two. Let me know what you need and Ill let you have it. It wont work on anything Ive got so pretty much useless to me. I paid $60 no joke for the entire truck and got back around $300 at the crusher after I robbed everything I wanted so im still in the green regardless.
Old 04-24-2008, 03:41 PM
4Cammer72's Avatar
4Cammer72
4Cammer72 is offline
ok guys, kinda hate to do this but, im going to be changing the front suspension on my 72 f100 to the 03 to 07 crown vic setup and im selling my front suspension. its all brand new to include rotors, bearings, kingpins and bushings, calipers, pads, and complete performance suspension urethane kit (220.00 itself). tierod ends draglink, powr steering box (the only used item here) ibeams and springs, all beams plates and calipers are painted. calipers with caliper paint, bright red, beams with urethane aspen glacier silver. everything to replace youre tired front end with 0 miles on it... pics can be seen in my gallery. 803-600-1555 steve. $400 obo
Old 04-25-2008, 07:05 AM
bob1987f's Avatar
bob1987f
bob1987f is offline
I just went through my 5.0 in my 87 (cam, heads, edelbrock intakes, ect.) and ive got a lot of perfectly good stuff left over that ill let sit and rust if i dont get rid of.
-factory efi intakes upper and lower
-factory e7te heads with only about 30k since a rebuild, perfect shape just a little dirty
-factory valve covers, fine but dirty
-smog pump crossover tube and egr valve with newer evp sensor on it (work perfect, just removed and eliminated them)
id take a hundred bucks for all...Lexington area
(i have other misc stuff but cant think of it all right now)
Old 04-25-2008, 09:42 AM
sysman_rick's Avatar
sysman_rick
sysman_rick is offline
Post
I'm looking for 20 inch wheels for 2005 screw(6 lug). Preferably oem.
Old 06-24-2008, 12:00 AM
sicktight722's Avatar
sicktight722
sicktight722 is offline
Heres what I got if anyone wants them. If not getting thrown away.
60/40 seats out of '89 Ranger. Decent condition with normal wear on them. The driver side one has a small tear. I do not have the tracks for them. Red Color.
a set of manual locking hubs for a Dana 28. I believe I have everything to convert the auto locking to the manual locking, except for one of the rings with the holes in them and the C-clips.
a rear window from a '84 bronco II, and the piece that holds the spare tire holder to the door, but is a little bit rusty.
Fan Shroud from a '84 bronco II with a 2.8L engine.
Last thing I have is head lights, turn signal lens and corner lens from a '89 ranger. The head lights have turned yellowish color that they all turn. They also have holes drilled in them to allow water to drain. I believe they are all in good condition. Even though the pic only shows one side, I have both sides.
Pics of the items. Located in Effingham SC, outside of Florence.
Bigsexy1086/For sale - Photobucket - Video and Image Hosting
Old 07-05-2008, 09:55 PM
STGFordCrazy04
I havent posted in the classifieds for some time but Ive still got a bunch of stuff for sale.
Ive got:
Ive got absolutely anything for a 73-79 F150 250 350 2 or 4wd with the exception of body panels. Im keeping that for myself.
In addition Ive got
351C/M 370 400 429 460 Pro Comp HEI dizzy - big cap
351C 351M 400 alum valve covers
Auburn gear locker for a 8.8 rear
2- NP208 transfer cases
9" and other ford/dana rears with all different gear ratios or individual parts
Any Ford carb'd engine you can think of and parts
2- 9'6" homemade one man sneak boats on side by side trailer. They were made with 3/8s AC marine grade plywood and the seams were fiberglassed. One boat has a 35lb thrust(or 37 not sure which) and the other has a 42lb thrust and will push me (165-170lbs) plus gear up river. They have not been registered in a few years but I use them almost monthly in a farm pond. They have no problems what so ever but I want a bigger 2 man boat for the river. Make an offer.
Im looking for:
a timing chain cover for a 460
10qt oil pan out of a 80s F600-700 with a 370 or 429
Holley 850 double pumper or Proform 850 (new rebuilt or used)
4" front leaf springs for a 99-04 F250 with a 5.4 gas engine
A short bed for a 73-79 Ford truck.
Thanks guys
Old 10-13-2008, 04:19 PM
nutfarmii's Avatar
nutfarmii
nutfarmii is offline
Looking for a carburated 302 to fit in 78 F100 any body know where to get one reasonable?
Old 10-13-2008, 07:33 PM
01blueedge's Avatar
01blueedge
01blueedge is offline
I have an 1987 ford Ranger 4x4 extended cab for sale it has the 2.9v6 and auto trans. It needs some work the fuel pumps aren't turning on $900 OBO
Old 10-17-2008, 08:27 AM
kmansford's Avatar
kmansford
kmansford is offline
1997 to 2003 parts
I have eldlebrock headers never installed, and a superchip tuner for sale. You will need to get gaskets and bolts for the headers. the tuner was used on 2000 ford 5.4. If interested let's make a deal. I live in Georgetown SC PM me if interested I can send pics
Go *****
Old 01-18-2009, 05:37 PM
jeff351's Avatar
jeff351
jeff351 is offline
lift kit
Looking for 4" lift kit for my 90 F150 XLT 4x4.
Preferably 'used' as I have more than 1 project at any given moment and have to watch my budget.
I missed out on an ebay auction a few months back, havent seen any since then.
The closer to upstate SC the better.
Old 03-22-2009, 08:22 AM
IllRespect's Avatar
IllRespect
IllRespect is offline
Buckseats
Got a set of bucket seats with center console and back seat out of a 92 extended cab. If interested pm me, Pictures upon request. I live in Dalzell, SC.
Old 03-30-2009, 11:04 AM
IllRespect's Avatar
IllRespect
Here are the pictures of the seats.
https://www.ford-trucks.com/user_gallery/displayalbum.php?albumid=38229
Quick Reply: SC Archived Buy/Sell/Trade Ads
