hi/wiring ?
Old 03-27-2010, 12:48 PM
trainwrecker's Avatar
trainwrecker
trainwrecker is offline
hi/wiring ?
i am new to this site and new to owning a 76 ford crew cab.
i live in salem, and i am looking for somebody to fix the wiring mess in my truck. i dont have the time or skill to do this my self so i am looking for a good shop or maybe a privite preson who is good at wiring to help me with this. any info with be a great help to me.
thanks
trainwrecker.
Old 03-27-2010, 04:27 PM
WarOzz's Avatar
WarOzz
WarOzz is offline
If I was closer I would give you a hand... what type of problems are you having and are you talking under the hood electrical, interior or lighting problems?
Old 03-27-2010, 04:33 PM
trainwrecker
i am having lighting trouble mostly. out of all the fueses in the box under the dash only 2 have power to them and the only thing that does not work is the break light. so i just cant figure out how everything else is working. and it seems to be mostly stock wiring and not all hacked up.
Old 03-27-2010, 05:13 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Check the grounds..........In older trucks, they are very suspect.
Old 03-27-2010, 09:57 PM
StevenhF100's Avatar
StevenhF100
StevenhF100 is offline
Check your emergency flashers, if they don't work either there is a fuse in the box that operates both. Bottom right fuse if I remember correctly, but should be labeled. Mine on my 76 was very corroded, had to scrape the contacts clean to get it to work.
Old 03-27-2010, 10:09 PM
trainwrecker
i will be checking that fues in the moring because the flashes dont work. tanks for the info.
Old 03-28-2010, 08:52 AM
WarOzz's Avatar
WarOzz
WarOzz is offline
On the old trucks the majority of lighting goes through the headlight switch... hence the reason it fails so often... to much power goes through it.
As for the brake lights check the fuse as previously stated, take some light sand paper and clean the fuse contacts while your at it. On these older trucks the tail light grounds come off the body so it is very important that the engine to body ground strap is clean and connected properly.
Old 03-29-2010, 06:40 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
"the only thing that don't work is the brake lights"
Brake light switch is on the brake peddle under the dash. Prone to failure........ Should have power to one side if the fuse and wiring is ok. If there is power at the switch and the switch itself works the problem is most likely in the turn signal switch. Another common problem.
laxdad
09-18-2015 11:50 AM
Mister_King
Electrical Systems/Wiring
03-06-2015 06:45 AM
charon61285
10-22-2004 08:27 AM
Oscar Meier
12-23-2003 10:06 PM
Quick Reply: hi/wiring ?
